1/4 mile question
Old Oct 30, 2004 | 07:28 PM
BkMaxima2004's Avatar
1/4 mile question
After owning my 00 SE for almost 9 month now i finally got around to taking her to the track last night. I went to the English town NJ and ran like 9 races. My first 2 were like 16.82-16.17.3, then the rest of them were preatty much in the 16.278-16.256, my best one was 16.235. As i was looking over the timing slips in the other forums i came across the breakdown an 1/4mile of every generation. It seems that my car should be able to do high 15's instead of low 16's. Personally i was expecting exactly what i got, but i'm starting to be a little worried now. Any of you guys who own a 00 SE automatic have the same numbers as i do or better. Also this 15's high is that considered with like all the junk in your trunk.
Thanks alot
Old Oct 30, 2004 | 07:57 PM
kratz74's Avatar
its most likely your shifting. To get fast times does not = smooth shifts. you are kind fo hard on the car to get the best times. Need to slip the clutch and pretty much dump it in every shift. On my motorcycle, No clutch is used in shifting and that saves .3 in the 1/4 mile.
Old Oct 30, 2004 | 08:03 PM
NYPD-Arnold's Avatar
Z
He doesn't even say he has a 5spd...He's in BK, NY so he more than likely has an auto. Dunno' what to tell you though, dude. Answer this:
Mileage of the car
Tire wear
Last fluid change
What you had in your car
How full was your gas tank
Old Oct 30, 2004 | 08:13 PM
My car is automatic, i have about 83000 miles on it, tires aren't all that hot, changed my ATF and my oil about 2 weeks ago, in my trunk i had the spare and some other stupid things that add up to most 8-10lbs, my gas tank was half
Old Oct 30, 2004 | 08:18 PM
niceguy's Avatar
Ouch...were you spinning tires off the line or something? Well, I guess the 16.2 isn't too bad. My old '93 Altima auto ran a 16.1 with I/P/Max muffler but like they said, it could just be your driving technique...What was your 60'? Maybe a 2.5/2.6??
Jeremy
Old Oct 30, 2004 | 08:21 PM
Z
I'd say it's your tires.
Old Oct 31, 2004 | 05:41 AM
Hmmm...i don't think my tires were the issue that much. my 60' was 2.5-2.6, lets say i had a good set of tires on what other factor can effect my 1/4 mile time. Also what is the average you guys run you 2000 SE automatic.
Old Oct 31, 2004 | 05:52 AM
Max_Gator's Avatar
it's you 60.
Old Oct 31, 2004 | 05:58 AM
Loe max's Avatar
Did you manually shift? 2k-2k1's need all the revs they can get to reach peak HP, unfortunately, the rev limiter prevents them from taking advantage of gearing. I ran IIRC 15.6@88mph (or was it 15.4?) with a 2.3 60ft time stock with my 00 GLE manually shifting. At the time, I still had the OEM Toyo Proxies AO2 which I thought where perfect for launches; brake TQ for a split second to about 1,400-1,600rpms and give it throttle at an even pace allowing it to chirp for a second and grip (not slamming it to the floor on launch, otherwise my 60ft times where 2.5-2.6)
Old Oct 31, 2004 | 10:06 AM
aliti19's Avatar
Maxima addiction cured w/ the GS pill
Try this post in the 1/4 mile forum. They might have some more answers for you.
Old Oct 31, 2004 | 10:32 AM
Z
Bring your 60ft down a bit and work on your launches.
Old Oct 31, 2004 | 12:47 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Change out your MAF, fix the broken VIAS and do coils and you will run some low to mid 15s.
Old Oct 31, 2004 | 03:40 PM
how would i change my MAF and coils and whats a broken VIAS, i'm sorry guys this are probably stupid question, but i'm preatty much just learning on how to work on my maxima. Thanks for all the help
Old Oct 31, 2004 | 10:08 PM
MAF repleacement is like installing a cone intake on your Maxima- but alot eassier to do- just 4 10mm bolts and then one hose clamp, unplug the connector and its out. Coils are just as EZ to do, but you need a allen head type socket to remove the front valve cover- coil cover, its the plastic one that says Nissan 3000 V6 Twin Cam. Then you will need a 10mm socket and ratchet to remove the 10mm bolt holding each coil in, just pull the coils out and unplug them. Don't discard the old ones just in case you have a coil problem in the future (unlikely as I have almost 60K on my new ones now-knock on wood). As far as broken VIAS- look for a thread on the forum here describing how to check its operation and how to fix it- its your variable intake air system, which is the whole intake manifold. Alot of 50+K Mile 00-01 Maximas that have been driven hard will have this problem- mine has been broke for over a year and I need to repleace the whole intake manifold as its too late to fix mine now. 260 bux for a new manifold- welcome back phat powerband.
Old Nov 1, 2004 | 08:42 AM
2k1seae's Avatar
My best was 15.905 @ 86.59 with a 2.45 60 ft and manually shifting. I expected more with the Y-Pipe install but only gained about .15 sec. I only had it on for about a week. I'll try again in the spring and see if the ECU has adjusted to it. I need to do some work on the launch.
rbuswell
Nov 17, 2016 04:54 AM
soloist3
Sep 2, 2015 12:59 PM
flu2000
22
Sep 2, 2015 07:29 AM
MikesChevelle
Aug 10, 2015 10:53 AM
