afraid my wheels are gonna fall off
Old Nov 6, 2004 | 03:10 PM
ColdSHO's Avatar
i finally recieved my rear wheel spacers, theyre 8mm's, i read on the org that i can use up to 10mm with the stock studs, but my lugs dont seem to have much thread to grip onto, seems about half of the lug. is that enough or do i need new studs, i plan on bumping up to 20mm's in the back eventually and i know i need new ones for those, but am i fine with my stock studs on my stock rims?
Old Nov 6, 2004 | 03:48 PM
WildmanAL's Avatar
Where did you get 8mm spacers from and what find are they? It probably would be a good idea sometime in the near future to get longer studs.
Old Nov 6, 2004 | 06:07 PM
Ammi's Avatar
350 Detroit Muscle
For 10mm spacers, get longer studs. 5mm spacers you can use w/ OEM studs.
Old Nov 6, 2004 | 08:30 PM
Fezzik's Avatar
You should be fine on stock studs with 10mm. 10mm is really the pushing point of getting new studs. Its ur call on this one. If you go any higher, then you will need longer studs. If you get H&R 20mm spacers. tehy come with new longer studs.
Old Nov 6, 2004 | 09:42 PM
ChromeSE5's Avatar
dont go off roading or careful on bumpy roads. I did something stupid (went and tried a short cut) and two lug nuts fell of one wheel. Other than that on smooth roads they should be fine (i put about 2k miles before hitting the dirt road).
bbsitum
Sep 6, 2019 07:31 PM
londonflu
40
Sep 25, 2015 09:11 AM
Max8
Sep 22, 2015 02:53 PM
Violator
Sep 9, 2015 10:14 AM
dcam0326
Sep 8, 2015 11:02 PM
