JIC owners step in Please
Old 11-07-2004, 11:51 AM
Max20SE00's Avatar
I am in the middle of an install on a 200 maxima. I heard these are Adjustable height when they are installed. It appears they can only be adusted off the car, becausde you cant turn them when they are bolted on. Please let me know if I am adjusting the wrong thing.
Max20SE00 is offline
Old 11-07-2004, 02:27 PM
RAZORFISH228's Avatar
Once you have them bolted on, you can adjust them by turning the bracket using the special tool. Make sure you measure everything before and after the install.
RAZORFISH228 is offline
Old 11-07-2004, 02:36 PM
Oh hi....
SeaFoam2DMax's Avatar
What Razorfish said. If you have bolted them you can only change height while losing strut travel. If you don't want to lose strut travel, undo the bottom and adjust. It takes time, but it is so worth it to have full strut travel.
SeaFoam2DMax is offline
Old 11-07-2004, 03:04 PM
Max20SE00's Avatar
Well for tonight I have the fronts only done. I have to drive the car tomorrow for work and school and wont be able to put the rears on till tomorrow evening. Cars probably going to ride weird. Shouldnt mess anything up should it?
Old 11-07-2004, 03:17 PM
5 spd's Avatar
http://forums.maxima.org/showpost.ph...&postcount=125
5 spd is offline
Old 11-07-2004, 04:41 PM
Hey kcgc187,
Tell me you have the same problem as I do. I put the setting to the softest setting and I think my car is bouncy and makes the swoosh noise. What setting do you have yours set to?
Oh yeah, when you turn the little screw, does yours go loose pass the clicking? I went past the clicking and now I'm scared I might have damaged it.
Old 11-07-2004, 06:10 PM
Bulldawg's Avatar
You will be fine about the adjustment screw as long as you can still click to adjust. If you adjustment screw is hard to turn, then you need to send them to JIC to get them fixed free of charge. ( had to do that once). I have had my JIC's for almost a year now. I have supplied many org members with my write up. Let me know if you would like to see it.
Bulldawg is offline
Old 11-07-2004, 06:12 PM
Bulldawg's Avatar
No you will not mess anything up with only the fronts other than an incredibly weird ride. I had mine like that for almost 1 month.
Bulldawg is offline
Old 11-07-2004, 06:24 PM
Oh hi....
Originally Posted by RAZORFISH228
Hey kcgc187,
I left them soft for a few days and that would describe the ride, but I have them set to 12 all the way around.
Old 11-07-2004, 06:26 PM
Bulldawg's Avatar
It doesn't matter how you adjust your coilover it is the same difference. You can only adjust you lower bracket so much, and the FLT-A2 are designed so that you won't lose "strut" travel even at the lowest setting. You can slam you car and still have maximum travel. That is the beauty of the A2.
The way to adjust height on the the car, fully bolted, is to leave your lock collar tight below the spring perch, and loosen your collar above the lower bracket. Then use the supplied collar tool, and "screw" the entire threaded section down into the lower bracket, by "tightening" the spring perch. If you want to lower the car 1/2 inch, then you loosen the lowest collar to where you see 1/2" of threads between the lower bracket and lower collar. When you are done tighten every thing back up.
If you need any help, you can IM me or call. I hate trying to explain stuff on the internet. 864-420-5283
Bulldawg is offline
Old 11-07-2004, 06:43 PM
imported_JIC_A33
Old 11-07-2004, 07:59 PM
Max20SE00's Avatar
Now, the noise these make when going over bumps, is this normal? I hear a swoosh noise when going over bumps, happens whehter they are set to firm or soft. I have the ALT-A1's not the a2's. So only 5 settings. didnt seem to feel much different between 1 and 5 though, maybe its just me.
Old 11-07-2004, 08:11 PM
stevay's Avatar
swoosh noise is normal....begin to like it after awhile.
stevay is offline
Old 11-07-2004, 08:14 PM
Max20SE00's Avatar
with the a1's should it be noticeable switching from setting 1 to setting 5?
Old 11-08-2004, 04:48 AM
cobymoby's Avatar
It's hard to tell if you are just driving around town. You've gotta really push the car to tell the suspension changes on the JIC shocks.
cobymoby is offline
Old 11-08-2004, 06:52 AM
ColdSHO's Avatar
ive noticed a huge differance between 1 and 5, totally differant ride characteristics. the roads by me are rather rough and im still searching for the best combo for daily driving,
2 in front and 1 in the back is my fav so far. is it bad to adjust them all the time, maybe once a week or so? and does anyone have a rear strut bar, i want one, but not sure how hard itll be to adjust the shock. its hard enough now, but i want that extra bit of stiffness.
sorry bout beng all over the place there. thought id just address as many issues with my jic's as possable.
ColdSHO is offline
Old 11-08-2004, 07:55 PM
Max20SE00's Avatar
Just got both sides done. Looks amazing, Once i get the car cleaned all up and back from the body shop I will get pics. Going to body shop repairing hurricane damage. I have about a finger gap in the front and about flush with the fender in the rear, but I will be raising the rear slightly because it is rubbing slightly. Ride is great though, not too bad at all. Still dont really notice much difference between 1-5 setting though, I will have to keep playing wwith it.
Old 11-08-2004, 09:09 PM
stevay's Avatar
bring it down, not up!
stevay is offline
gigabyte
01-06-2017 06:05 PM
D Mason
06-21-2016 04:43 AM
bernyp
10-02-2015 10:10 AM
Quick Reply: JIC owners step in Please
