Strange 'CLUNK' noise in front right wheel?
Old Dec 9, 2004 | 01:04 PM
str8max's Avatar
I have this strange noise comming from right wheel but the kicker is I can only here it when it rains! I was thinking its a wheel bearing or ball joint.
you hit a bump you hear the clunk or if you jerk the wheel hard left you can also hear it.
But once again this is only when it rains ......any other time its cool.
Any ideas
Thanks in advance
Old Dec 9, 2004 | 01:48 PM
Galo's Avatar
Maxima Pilot
Any ideas
Thanks in advance
Try lubricating the front right sway-bar bushings (te ones that mount the sway bar to the chassis itself- with Vaseline.....jack the front right up and use a small, flat-blade screwdriver to get it in there liberally.......then tell me if if clunks.
Old Dec 9, 2004 | 01:51 PM
str8max's Avatar
but why would it do it only when it rains?
Old Dec 9, 2004 | 07:30 PM
str8max's Avatar
anyone else got any ideas?
Old Dec 10, 2004 | 06:02 AM
str8max's Avatar
bump bump bump
Old Dec 10, 2004 | 02:02 PM
Maxima Girl's Avatar
Mine makes the same noise I have it in the shop today they said it's my wheel bearing also that my strut that's leaking. First I could only hear it once in a while then it became more frequent! I guess I will see when I pick it up if the noise was fixed by replacing the bearing... I am having my illumina 5 ways installed and springs... oh and the dang bearing! So I will let ya know what they say!
Old Dec 10, 2004 | 05:35 PM
str8max's Avatar
well I just replaced my struts this summer with KYB's and Eibach springs.....
Let me know what you find out!
Old Dec 11, 2004 | 09:34 PM
Hi I just got my max back I installed the illuminas and springs. Turns out my axel socket was loose! It's a 32mm socket that is at the end of your cv shaft. Check it out and make sure they are all impact wrench tight! That's about all the info and ideas I got for ya! Let me know...
Hondarydr
Dec 30, 2024 06:15 PM
boomerbrian
Nov 8, 2015 05:10 PM
official_style
Aug 29, 2015 10:10 AM
KGMtech
Aug 18, 2015 09:21 AM
carlosvq30
Aug 17, 2015 11:32 AM
