Keyless Entry Trunk Release Problem
Old Jan 2, 2005 | 03:11 PM
MerlotMax01's Avatar
My 2001 Max SE has a rather annoying (though small) problem -- the trunk release only sporadically works from the remote. If I'm lucky it will work on the 4th or 5th button push, but usually I just have to give up and use the key.
The remote door lock/unlock works just fine, and the problem occurs with both transmitters. The trunk release on the driver door works fine, too, so the issue doesn't seem to be in the relay. I've checked fuses and checked the obvious connections and couldn't find anything, but I suspect it's a bad/loose wire somewhere.
Has anyone else had this issue or have any ideas? I appreciate your help!
Old Jan 2, 2005 | 07:09 PM
blackjackmark's Avatar
eliminating the (probably) obvious?
On mine, you have to hold the button down for 1 or 2 seconds, otherwise it doesn't work. When I first got it a few weeks ago, I thought it didn't work, then quickly discovered that trick.
Old Jan 2, 2005 | 07:57 PM
Thanks for the suggestion - I've tried that before as well, but it doesn't help. Since it seems to work randomly, that's why I'm leaning toward a bad wire somewhere.
Old Jan 2, 2005 | 08:46 PM
nismo_star's Avatar
Check striker release harness in actual trunk lid, worse comes to worse it probably is your striker.
Then again, do you have an add on alarm system ??
I've seen some amateur alarm wiring jobs that really fizzle me good when I diag electrical bugs
Old Jan 2, 2005 | 08:52 PM
jrod1014's Avatar
check the battery of your remote? this might have something to do with it... good luck...
Old Jan 3, 2005 | 06:11 PM
Thanks for the suggestions -- I'll check the trunk lid wiring this weekend & let you know what I find...
RWCreative
Sep 21, 2015 11:01 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
flu2000
Sep 14, 2015 12:34 PM
rbaker100
Sep 6, 2015 02:46 PM
Hailstatejig
Sep 2, 2015 06:52 AM
