Helppp My 2000
Helppp My 2000
When i was driving home last night the car was ver very rough the idle was really bad. when i drove the car it sounded like something was clogged or some junk. th car shifted fine but when im in first gear it would take a good while before it it was goin fast enough to shift out to 2nd. my gas milage has gone down. from 320 a tank to 280, now 260. wat could be the problem i know its not my MAF, it might be my coils, or (GOD FORBID) my tranny.
The dealer checked out my car and said theres nothing wrong with the engine it fine, what do you guys think im really in a bind and have no idea man. Thanks for all the input
Originally Posted by NOCturnalI30
No codes came up and i hear like a pining noise as im hitting the gas
Definitely on track with the MAF or coils. Do the MAF first!!!!!! It's a hell of a lot cheaper than 6 coils. I work at a Nissan dealer in the parts dept and we can't keep those MAF's on the shelf, but of course the coils have also been on backorder. but definitely do the MAF first. While your at it get an inductions service and change the fuel filter, and dont let them fool you that the fuel filter shouldn't be changed. I just had it changed and it took one of my technicians 10 minutes to do the job.
sounds like the MAF, the MAF's on the 2000-2003 maxima's were horrible. The coils aren't good either. I would check the maf first. if you go to www.car-part.com you can get a new MAF for cheap. On the 2000-2001's i've heard you can get just the Insert piece for the maf tube and it's mucher cheaper but i don't remember the part number. good luck.
Originally Posted by Charliejag
Is the MAF the tubular sensor that is part of the intake or is it the small square sensor that is next to it?
i'm haveing the same problems. all the same problems NOCturnalI30 is haveing. At first i got a SES light that came up to be a DTP1320 1302 i think? Anywho.. It was bad coils. SO i got that changed all 6. Ok that problem solved but it still runs like $HIT!!!!!!!!!! I'm gonna change the MAF this weekend and see if ne thing gets better.. I hope so.. cuz this really sucks trying to find a problem were the ECU dosen't through a code for.. i'll post up when changed the MAF...
actually if i slam the gas the car will goo but it wont under like 2k-3k rpm????????
http://forums.maxima.org/showthread.php?p=2984783
TKHanson
Nov 24, 2018 01:39 AM
Need help
23
Oct 2, 2015 08:56 AM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
