95 y pipe/mods to the 2000?
Old Jan 20, 2005 | 06:09 PM
cleanmax02's Avatar
I recently Have moved on from the slightly modded 95' SE to the new 2000 SE and am wondering what mods if any could be swapped. I have Sprint springs/tokico shocks. Stillen Y-pipe, B pipe and the place racing CAI. Any input would be GREATLY appreciated! Thanks guys!
Old Jan 20, 2005 | 06:17 PM
upstatemax's Avatar
i know the stillen y-pipe for the 2000 max showed to give no gains... actually i think it did worse...
Old Jan 21, 2005 | 12:51 PM
cleanmax02's Avatar
would it even fit? What about any of the other stuff?
Old Jan 21, 2005 | 01:08 PM
GreenSeMax's Avatar
the stillen y will fit, but only uses the rear section on CA/NLEV cars, the rest of the exhaust is different, other than that you CAI is the only other part I know you could use on the 2000. I don't know much about the spring/strut interchangeability. As for the y pipe not making any power................not happening..........losing power..........definitely not happening.
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
you thought wrong. dyno have proved gains with just about every y pipe to be at minimum 10-12hp on cali spec 2k and slightly higher on fed spec 2ks. i personally would not buy a stillen y pipe but they gain power on 5th 3.0 motors. if your 4th gen was a cali spec and so is your 5th then it should fit. same if the 4th was fed and the 5th is a fed spec.
the cai would physically fit but the vacuum lines wont match since your 4th gen had 2 and the 5th gen requires 3. you could get creative if you were inclined.
pretty sure the b pipe wont work due to different bends and lenght difference. not sure on the suspension stuff, i would think no but maybe someone else can shine some light on it.
Old Mar 13, 2011 | 10:37 AM
hornepirate's Avatar
Sorry to bump an ancient thread but figured it would be better than to start a new thread but just to clarify A y pipe for a Fed spec A32 will fit right up to a Fed spec A33 (3.0) aside from the addition of a few new O2 bungs?
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
Need help
23
Oct 2, 2015 08:56 AM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
