How to remove tail lights
Old Feb 2, 2005 | 07:02 PM
Ninetein's Avatar
How are the tail lights removed on a 5th gen?
Old Feb 2, 2005 | 07:29 PM
SoonerFan's Avatar
Cletus
open trunk
pull back truck liner
remove bolts (3 per light i think)
wiggle and pull like h3ll to loosen up the seal
Old Feb 2, 2005 | 07:31 PM
mattattax's Avatar
4 bolts
Old Feb 2, 2005 | 08:10 PM
bigsherv's Avatar
How do you put it back in and keep it all water tight?
Originally Posted by soonerfan
open trunk
Old Feb 2, 2005 | 08:39 PM
crispykid717's Avatar
Bigger than Jesus
Reverse process but add more sealant.
Old Feb 2, 2005 | 08:53 PM
Ninetein's Avatar
Originally Posted by mattattax
4 bolts
Thanks! Is it an 8mm or 10mm bolt?
Old Feb 3, 2005 | 08:34 AM
mattattax's Avatar
I think it's 8
Old Feb 3, 2005 | 09:16 AM
LA02MAX's Avatar
i thought it was 10? i just tried this the other day, and i used a 10mm
Old Feb 3, 2005 | 10:44 AM
BRAN808's Avatar
I just swapped mine for '02 T/L's, and I could've sworn that I used an 8mm.
Old Feb 3, 2005 | 10:48 AM
Puppetmaster's Avatar
I think its a 10mm... either way... its just a matter of finding the right socket size... why is that such a big deal?
Old Feb 3, 2005 | 11:14 AM
jazzyjay's Avatar
Harness
I have a set of 02 tails I will be installing on a 00. Are you guy buying the harness for the dealer or are you going to the salvage yard for it. What is the price and part # at the Nissan dealer.
Old Feb 3, 2005 | 11:17 AM
NmexMAX's Avatar
dot dot dot ...
would you need a harness?
Old Feb 3, 2005 | 01:45 PM
mattattax's Avatar
We'll just say it's 9.
Old Feb 3, 2005 | 02:28 PM
BRAN808's Avatar
To convert from '00-'02 you need to use the harness (on the '02 lights) and they'll just plug into the socket from the '00 (bodyside). Did that make sense?
Old Feb 3, 2005 | 02:36 PM
spring02's Avatar
You need an 8 mm socket for the tail light swap. You will also need the 2002 wiring harnesses, b/c the bulbs are different (you need new blinker bulbs for sure; buy them at Autozone). Harnesses are about $20 each from Dave B, and you also need 1 roll of black sealant (one roll will do both new tail lights). Sealant is around $15 from Dave B. Reuse the locking nuts from the old red tail light housings; takes about 30 minutes to switch the lights. Good luck with the switch, it looks a lot better after you're done!
Old Feb 3, 2005 | 02:46 PM
I swapped my 2k2 tails with some 2k1s from another .Org member.... we did it in the parking lot of his apt complex and it was a direct swap, including the harnesses... not sure why ya need to buy harnesses or bulbs....
Old Feb 3, 2005 | 07:59 PM
spring02's Avatar
Well, then I did it the hard way Puppetmaster. Dave B was the guy who said I needed the 2k2 harness, and I'd like to think he wouldn't steer me wrong.
Old Feb 3, 2005 | 08:04 PM
No... he has a good rep and is trustworthy... I guess maybe the lights ya got just didn't come with em? I dunno... its hard for me to really know unless I knew your exact situation... AE SEoulchild and I swapped the entire housings and harnesses with nothing additional needed... we didn't even add new sealant (which was probably a bad idea, but so far so good... )
Old Feb 5, 2005 | 05:56 AM
jazzyjay's Avatar
Tail lights
I went the dealership and that part that the bulbs twist in to can be used from you "00 tail lights it has two philps screws and two tab holding it on. Use that part for your "00 lights it fits directly in to the "02 housing. This way is the cheapest and simplest way not to buy that harness. It only cost $24 at your local dealer
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
