FIRST LOOK! SSR/SFR Turbo Kit for 5th Gen
Old 03-09-2005, 10:34 AM
  #241
Still Here... IM me for more..
HNDA ETR's Avatar
Originally Posted by Larrio
Bigger wastegate for lower boost levels. At lower boost, you'll be diverting more exhaust gas, therefore the larger WG needs to flow more. Higher boost levels will have more exhaust going through the turbo, and less through the WG, so it can be smaller.
This all assumes a properly sized turbo, and all other things equal of course.
Exactly... and the biggest reason of all, which ties into what Larry (or is it Andy? ) said, is that the bigger WG will better prevent boost spikes, which would grenade the engine...
HNDA ETR is offline
Old 03-09-2005, 10:36 AM
  #242
HNDA ETR's Avatar
Originally Posted by slimer
havent visited this thread for a while! those welds look freakin awesome
Yeah, Tim at SFR is an awesome welder!
HNDA ETR is offline
Old 03-09-2005, 10:40 AM
  #243
HNDA ETR's Avatar
Originally Posted by 5thgen2nr
Let me guess....auto 5th gen 3.0L drivers(like me) are left out of the forced induction party again?
Uhhh... what about the Stillen Supercharger kit (which is what I had on my 2K Maxima)?
And don't forget the PFI turbo kit (http://www.turbokits.com/maxima_turbo_kits.html)
HNDA ETR is offline
Old 03-09-2005, 11:40 AM
  #244
SSR Engineering's Avatar
We are definitely working on a way to make this affordable for everyone.
SSR Engineering is offline
Old 03-11-2005, 04:50 PM
  #245
HNDA ETR's Avatar
Piping should be back from getting thermal coated Monday or Tuesday... Hopefully pics soon afterwards...
HNDA ETR is offline
Old 03-13-2005, 06:18 AM
  #246
mingo's Avatar
good stuff man.. i'm wondering whether or not the feed pipe would add excessive heat stress to the radiator causing it to crack or melt the fan shroud.. i've thot of running my piping infront of the motor mount but have been skurred... please keep us posted =D g'luck with the project
mingo is offline
Old 03-20-2005, 07:06 PM
  #247
Oh hi....
SeaFoam2DMax's Avatar
bbbbbbbbump, updates?
SeaFoam2DMax is offline
Old 03-22-2005, 10:32 AM
  #248
6yrs old=36,500 miles :)
harmbone2k2's Avatar
how is it comin hondaetr?
harmbone2k2 is offline
Old 03-22-2005, 10:44 AM
  #249
HNDA ETR's Avatar
Tim thinks he'll have the car done this thursday... the jet-hot coating took longer than expected to complete, so he's supposed to be getting the piping back today from them.
I'm on call for jury duty this week, so the plan is to go down next week and dyno the car/take it home...
no new pics yet...
HNDA ETR is offline
Old 03-22-2005, 10:52 AM
  #250
Puppetmaster's Avatar
no new pics yet...
Can't wait to see those dynos man...
And pics too of course...
Puppetmaster is offline
Old 03-22-2005, 11:00 AM
  #251
Play with my balls
Deckdout2's Avatar
this is gonna be nasty!
Deckdout2 is offline
Old 03-24-2005, 07:16 PM
  #252
HNDA ETR's Avatar
pipes back from coating... just waiting for pics...
HNDA ETR is offline
Old 03-24-2005, 07:20 PM
  #253
mingo's Avatar
OH nice...
mingo is offline
Old 03-27-2005, 12:21 AM
  #254
HNDA ETR's Avatar
Pics finally in...
Here are all the parts laid out:
Downpipe attached to rest of exhaust:
Front of downpipe:
HNDA ETR is offline
Old 03-27-2005, 12:24 AM
  #255
HNDA ETR's Avatar
Other side of downpipe:
Pic of rear header and crossover pipe:
Another:
HNDA ETR is offline
Old 03-27-2005, 12:27 AM
  #256
HNDA ETR's Avatar
Downpipe and crossover piping:
Front Header:
Another:
HNDA ETR is offline
Old 03-27-2005, 12:28 AM
  #257
mjg
mjg's Avatar
damn.
8 char.
holy crap.
mjg is offline
Old 03-27-2005, 12:30 AM
  #258
HNDA ETR's Avatar
O2 Sensor plugged into downpipe - Can anyone spot the problem that Tim ran into?
Another hint:
Last hint:
HNDA ETR is offline
Old 03-27-2005, 12:43 AM
  #259
HNDA ETR's Avatar
Answer to problem:
If you notice in the first pic (of the 3 problem pics) the piping that connects the rear header with the front header, and then feeds into the turbo, is almost touching the radiator. Also, none of the pipes is lining up correctly anymore.
What happened was that originally, I had the Place Racing motor mounts installed. So when Tim fabricated all of the pipes, he did it with the PR motor mounts.
When Tony and I went down and replaced the PR motor mounts, with the ES motor mounts... well, you can see in pics 2 and 3 the difference in how the motor mount cage is made. The OEM motor mount cage (with the ES motor mount bushing installed) is much wider than the custom made PR motor mount.
So the solution that Tim came up with, is to cut the OEM motor mount to accomodate the pipe. Basically, he's going to cut a notch into the OEM motor mount, and then weld a new plate of steel onto the mount to re-box it in. Tim says the mount will be stronger than the OEM mount after this...
How does this affect any future kits, you ask? Well basically, Tim will include an OEM motor mount that he's already modified along with the kit. So there won't be any tweaking needed on the kit buyer's part...
HNDA ETR is offline
Old 03-27-2005, 12:45 AM
  #260
HNDA ETR's Avatar
Pics of my HKS SSQV blow off valve:
HNDA ETR is offline
Old 03-27-2005, 01:05 AM
  #261
CEFIRO's Avatar
Insanly NICE!
CEFIRO is offline
Old 03-27-2005, 05:00 AM
  #262
mingo's Avatar
man, those are some quality pipes
hella nice..
mingo is offline
Old 03-27-2005, 05:57 AM
  #263
mingo's Avatar
oh yah, i hope that flex section is long enough. so why did you take out the PR engine mount? did you think it would melt or something?
mingo is offline
Old 03-27-2005, 06:09 AM
  #264
doublea's Avatar
Keep up the good work, it sound like the next year saving will fly right into your pocket so my baby can have a new dress.
doublea is offline
Old 03-27-2005, 09:49 AM
  #265
Future Camaro SS owner
MyownNismo's Avatar
I don't think this will fit on a auto. but I hope it will with some adjusting.
MyownNismo is offline
Old 03-27-2005, 11:11 AM
  #266
drag racing is for wussies
BlackBIRDVQ's Avatar
how much for just the manifolds, ypipe and the downpipe ? uncoated ofcourse.
BlackBIRDVQ is offline
Old 03-27-2005, 01:08 PM
  #267
Wait until we finish it up, I'll have the prices posted on this site ASAP.
Old 03-27-2005, 01:55 PM
  #268
doublea's Avatar
Doesn't really matter if it dont fit an auto, cuz my max will get a stick transplant next winter while the car is winterize ( is this a word )
AA
doublea is offline
Old 03-27-2005, 02:20 PM
  #269
mjg
mjg's Avatar
doublea;
this kit is for the 5.5 gen specifically. You might want an 02/03 max first... (or get some other kit).
mjg is offline
Old 03-27-2005, 02:41 PM
  #270
Originally Posted by mjg
doublea;
we will be making the changes to fit this kit to 4th 5th 5.5 and 6th gen maximas
Old 03-27-2005, 02:53 PM
  #271
mjg
mjg's Avatar
cool,sorry for this misinformation.
mjg is offline
Old 03-27-2005, 03:20 PM
  #272
exhaust fits 3.0ls also, I have 3.5L HS headers on my 3.0L.
Old 03-27-2005, 04:09 PM
  #273
HNDA ETR's Avatar
Well, originally, I wanted to change them for the ES mounts because the PR mounts made the car vibrate a bit too much for me...
Then, when I read the threads about them melting when headers were installed, that was a secondary reason....
Of course, I had them on for a few months with the headers and when we took them off, they were in perfect condition...
HNDA ETR is offline
Old 03-27-2005, 05:27 PM
  #274
jcton20s's Avatar
Please tell me this is going to fit the 6th gen 5spd auto tranny!?!?!? I have to have one of these!
jcton20s is offline
  #275
michaelnyden's Avatar
blackbird....do you have a video of what the hotshot headers sound like on your 3.0? did you have to have a shop put a EGR connector in there for you?...anything else that you had to custom fabricate or alter to bolt 'em up?
michaelnyden is offline
Old 03-27-2005, 05:35 PM
  #276
makavelisk's Avatar
I cant wait to see this thing all done.
makavelisk is offline
Old 03-27-2005, 05:36 PM
  #277
my rear view mirrors flap like a f-ing bird
Tek-Niq's Avatar
HAHAHA me too........
Tek-Niq is offline
Old 03-28-2005, 10:13 AM
  #278
doublea's Avatar
I hear you, good stuff.
doublea is offline
Old 03-28-2005, 10:35 AM
  #279
Maxima-Ness's Avatar
any more pics???
Maxima-Ness is offline
Old 03-28-2005, 10:41 AM
  #280
HNDA ETR's Avatar
Originally Posted by Maxima-Ness
any more pics???
Did you not see the 9-10 pics i just posted above?
HNDA ETR is offline
Quick Reply: FIRST LOOK! SSR/SFR Turbo Kit for 5th Gen
