Starter is going out, Need alittle help . .
Old Mar 2, 2005 | 12:12 PM
Max_Vader_2K's Avatar
Car would not start this morning and had to boost it to get going. Made it to auto zone and they check the battery and alternator both are good. The guy then tap on the started, and it started. I found a starter at NAPA for 184.00 How is the install of this thing.
Old Mar 2, 2005 | 12:52 PM
MrPoisse's Avatar
Here's what I have (not from me, got it a few weeks ago on the org and saved it).
Hope it helps.
Start Removal/Installation & Re-greasing:
Estimated Time: 1.5 hours
Tools Needed:
--Metric sockets: 10MM, 12MM, 14MM, & 17MM (deep sockets)
--3/8” (recommended due to tight space) or 1/2” drive with small extension.
--Philips head screwdriver
--Hi-temp multi-lube silicone grease
--Brake or carburetor cleaner
--Nissan ESM or FSM (not required, but highly recommended, look at page SC-19)
All steps consider person at the front of the car facing the engine bay.
Part I: Start removal
Step 1: Disconnect negative battery terminal.
Step 2: Remove intake assembly. (I suggest removing everything up to the throttle body, you will need the room.
Step 3: Detach harness protector that is above the starter and to the left of the battery. This is quite difficult to do without breaking. I ended up breaking mine, but it wasn’t that big of a deal to me because I didn’t feel the need to have the harness clamped in. But if you want to remove without breaking take your time and be patient, you have to separate the protector clip from the mounting bracket.
Step 4: Disconnect starter harness connecting the start solenoid to the power supply wire using a 12MM socket or open ended wrench.
Step 5: Loosen upper 14MM bolt with a deep 14MM socket and 3/8” or 1/2" drive. Requires some force to be removed.
Step 6: Loosen and remove lower 17MM bolt with deep 17MM socket or a 17MM socket and extension. This requires a lot of force to remove.
Step 7: Pull starter away from engine at a slight downward and away angle. This requires some maneuvering to remove from the engine as there is little room to work with. Removal of the battery may help in this situation, but I didn’t end up having to remove the battery.
Part II: Disassembly & Cleanup of the Starter
Step 1: Using brake or carburetor cleaner clean the outside housing of the starter and the solenoid.
Step 2: Remove the solenoid using a 10MM socket on the two 10MM bolts. Loosen the top bolt connecting the power supply cord. Carefully remove the solenoid from the starter. Keep a close track on the parts as to how they came off and where they go. These parts do not need to be re-lubed unless you have excessive mileage (probably 75K or more). Mine did not require to be re-lubed, the grease was still viscous and not hardened.
Step 3: Remove the rear cover from the starter using a Phillips head screwdriver on the two screws. You might notice a lot of copper filing and dried grease in the cover. This should be cleaned.
Step 4: Remove the two 10MM Through-bolts.
Step 5: Carefully pull apart the upper assembly containing the charging elements of the starter. This includes the brush assembly, armature assembly, yoke assembly, and center bracket. Clean the yoke assembly and center bracket with brake or carburetor cleaner. The brush assembly and armature assembly can be cleaned with compressed air, or stiff bristle brush. Keep track of the parts and how they were removed.
Step 6: Remove the internal gear, packing, and planetary gear. These need to be cleaned and re-greased with high temperature grease.
Step 7: The rest of the starter should come out basically as one piece. I would suggest leaving it as is, except for re-greasing the pinion shaft as much as you can. The intricate parts such as the rings requires special tools and in my opinion are not worth acquiring for this task.
Step 8: Clean gear case assembly.
Part III: Starter Assembly
Step 1: Assemble the starter. Keep a close track on the parts. I re-lubed the packing, planetary gears, and internal gear as I re-assembled the starter. Be sure to line up the holes in the center brackets, yoke assembly, and brush holder assembly. They need to be aligned so the Through-bolts can reach the bottom of the starter and be tightened.
Step 2: Replace the starter solenoid. Be sure to assemble all parts in the correct configuration!
Step 3: Tighten all bolts. From the ESM there are torque specifications, but I tightened all bolts finger tight and then 1/4 turn.
Part IV: Starter Installation
Step 1: Put start back in place using the reverse order of removal instructions. Be sure to finger tighten all bolts before tightening them down all the way!! Use the deep sockets to get the bolts started, unless you have small hands and can start the bolts without the sockets. Finger tighten 14MM, 17MM, and 12MM bolts. Tighten 12MM bolt connecting the power harness to ½ turn more than finger tight or per the required torque specification. The 14MM and 17MM bolts tighten with a large amount of force.
Step 2: Re-install harness protector.
Step 3: Re-install intake.
Step 4: Reconnect negative battery terminal.
Start the car and enjoy the whine free sound!
Old Mar 2, 2005 | 01:38 PM
Pri63's Avatar
anyone have a write with pics?
Old Mar 2, 2005 | 02:49 PM
Ammi's Avatar
350 Detroit Muscle
use this as reference
http://www.motorvate.ca/mvp.php/500
Old Mar 2, 2005 | 02:50 PM
Thanks that was extremely helpful, Pics would be nice though. I think I will have to let someone else put this in. Just by looking at it I thought it would have been easier than that. I don't have the tools to get this one done.
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
ballerchris510
Sep 11, 2015 05:29 PM
ballerchris510
Sep 10, 2015 09:35 PM
