clutch squeaking?
Old Apr 7, 2005 | 06:54 PM
skierxx5556's Avatar
clutch squeaking?
so i just installed my frankencar intake yesterday and today im out for a little drive and because it was such a nice day i had the windows down and when i was at a slow speed and would shift from 1st to 2nd i could hear a squeaking coming from my clutch now i dont know if this is something that i should worry about... has anyone experienced this before? could this be caused from the intake or maybe something rubing against something when i installed it?
Old Apr 7, 2005 | 06:58 PM
djsoniq's Avatar
Mine does this, there is actually a TSB out for it, but I don't know what causes it. Sounds like a howling noise. And it only happens once in a while...
Old Apr 7, 2005 | 06:59 PM
this is the first time that i have ever heard it... and ive had my car for about 9 months
Old Apr 7, 2005 | 07:03 PM
Ammi's Avatar
350 Detroit Muscle
squeak when your clutch is engaged or disengaged?
Old Apr 7, 2005 | 07:04 PM
when i am engaging it like when i push it in to shift from 1st to 2nd
Old Apr 7, 2005 | 07:16 PM
Ammi's Avatar
350 Detroit Muscle
sounds like TOB problem. I wouldn't worry too much.
Old Apr 7, 2005 | 07:20 PM
Tob??
123456
Old Apr 7, 2005 | 07:22 PM
Ammi's Avatar
350 Detroit Muscle
throw out bearing
Old Apr 7, 2005 | 07:49 PM
Igor911's Avatar
yeah there is a rubber boot under the intake on the tranny.
Pop it off and put some high temp lube in there.... works for me all the time
Old Apr 7, 2005 | 07:55 PM
vsamoylov
i have this problem sometimes but nothign to worry about it i guess. igor911, you mean the boots on the shifter cables?
Old Apr 7, 2005 | 07:57 PM
Igor911's Avatar
yes, pop it off. use something that can go deep inside that hole to lube the TOB.
I lube mine every 2 oil changes
Old Apr 7, 2005 | 08:01 PM
vsamoylov
i am going to try that. what kidn of grease di you use? multi purpose grease? i have some mobil 1 multi purpose grease. also did you do it to both boots?
Old Apr 7, 2005 | 08:02 PM
indecentmax's Avatar
i've had the same thing but i just ignored it, good idea igor, try out this weekend
Old Apr 7, 2005 | 08:04 PM
Igor911's Avatar
I think your missunderstanding what boot im referring too.
I'll try to take a pic of it tom for you on my way to work.
Old Apr 7, 2005 | 08:07 PM
yeah im gunna give this a try does anyone have a pic of what the boots look like im not mechanicaly inclined at all... igor what do you use to lube it?
Old Apr 8, 2005 | 05:38 AM
Igor911's Avatar
This is where the boot it, it just pops right off. I used HIGH TEMP GREASE...goto your local auto store and tell them you need HIGH TEMP grease for the Throw out bearing in the tranny.
Old Apr 8, 2005 | 11:27 AM
vsamoylov
ohh that one. i see. i will try to do that. thanks
Old Apr 8, 2005 | 12:31 PM
djsoniq's Avatar
I'll have to try that. I don't know if mine is a different problem but on my car the noise happens when I let the pedal up, and only when shifting into first.
Old Apr 21, 2005 | 04:46 PM
dblrr900's Avatar
Igor...
I tried what you said to do but not getting results. It is tough to even get in there. I am using a grease gun, but not really sure I am hitting the right spot. Did you use spray lube or actual grease?
R
Old May 30, 2005 | 06:39 AM
mdloops's Avatar
What happens when this part completely wears out?
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
SusieQQ
Sep 9, 2015 12:14 PM
