SAFC II install questions...
Old Apr 20, 2005 | 05:25 AM
dadiesel's Avatar
I finally recieved my SAFC II yesterday . I have a few questions I need answered if possible. I have the Maxima 2001 disc with all the ECU ports and what they are, but I can only locate the Knock Sensor, Throttle Position Sensor, and 3 different 'ECM grounds'. Which 'ECM ground' do I use, and is it correct that I only use one and tap into that one twice?(the 1cm thing) Any help would be appreciated!
Old Apr 20, 2005 | 06:37 AM
harmbone2k2's Avatar
6yrs old=36,500 miles :)
The only help I can give you is take it to someone who can install it for you.
Old Apr 20, 2005 | 07:06 AM
dadiesel's Avatar
They still have to know which ECU inputs are which.
Old Apr 20, 2005 | 08:36 AM
frankd121's Avatar
http://www.apexi-usa.com/productdocu...AFC2Wiring.pdf
Not sure if this will help, but it does have wiring diagrams. I can't locate the Max on it, but they do have the Cefiro on there which is pretty much the Max equivalent.
Does anyone have a shop manual with the wiring diagrams???? I would like to know too...
Old Apr 20, 2005 | 09:11 AM
Ammi's Avatar
350 Detroit Muscle
I rather find out all the info and install it myself than having someone w/ no knowledge about Maximas do the install.
Old Apr 20, 2005 | 09:25 AM
Jime's Avatar
This should fix you up.
Here is the diagram from my 2k2, use the pinouts below for the 2k1.
Check out my pins to your manual to make sure. However I did use exactly the same descrip etc as on my 2k2 so they should be right.
According to the 2k1 Manual I have you should use: 25=Tach, 48=ECM Ground, 93 Knock Sensor, 61=MAF, 82=Throttle Sig, 110=Power.
Note that although you can hookup the Knock Sensor it won't function properly on an OBDII vehicle but its something to look at anyway.
Also you do tap into the ground twice, 1 cm apart, this is very important for it to work. Read the instructions on my diagram.
Old Apr 20, 2005 | 05:38 PM
Ammi's Avatar
350 Detroit Muscle
how many wires are on the SAFC?
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
