motormount inserts
Old May 3, 2005 | 10:38 AM
xlcrew's Avatar
I’m Back
motormount inserts
i have new urethane bushings for my motor mounts and want to put them in, in the how to's all i see is one for the 02-03's. mine is a 00 is there any difference, and if so could someone give me the how to on how to get it done. thanks
Old May 3, 2005 | 10:42 AM
spirilis's Avatar
I highly recommend getting it done professionally. A machine shop should be able to do it. I damaged my front mount trying to press out the old insert--not a good time. It's not that easy of a job if you're new to this kind of stuff like I am
Old May 3, 2005 | 10:58 AM
takkar's Avatar
Rpughly how much would it be to get the motor mounts replaced with OEM OR with aftermarket ones?
Old May 3, 2005 | 11:24 AM
PoLo's Avatar
2-Wheelin it...
i paid $60 and it was a rush job, and the guy stayed late to do it. i would say you shouldn't get more than 40, 50 at most. it takes literally 20 minutes to swap. if they have the right press, a few minutes. mine was torched until the rubber melted off, then they greased mine up and popped it in.
Old May 3, 2005 | 12:50 PM
takkar's Avatar
dumb question...but how many mounts do we have? do we need anything special since they are liquid filled and electronicly controlled?
Old May 3, 2005 | 12:56 PM
PoLo's Avatar
2-Wheelin it...
- 4 mounts. 2 hold it up (left and right), 2 control the movement (front/rear of engine)...we are replacing the 2 front/rear inserts. the other 2 have ZERO performance benefits.
- auto's are the only ones that are electronically controlled. it is loose when you're idling, and when you press on the gas, the control mechanism turns them stiff. i've been told that auto people could just ziptie that electronic control unit and just leave it hanging in there. if you unplug, you could get a CEL.
- liquid filled means nothing. our rear-trailing arm bushings are liquid filled. you drill in and remove the liquid, rip the surround, and replace with the new aftermarket bushing.
Old May 3, 2005 | 01:18 PM
Larrio's Avatar
The Definitive AE Master
saw a couple of local org members DIY the ES motor mount inserts last weekend.
One used a torch to get rid of all the crap in the middle, cut into the metal sleeve and pounded it out, leaving the motor mount bare. Lubed up the ES motor mount, aligned it, and pressed it in using a 2x4 piece of wood
Old May 3, 2005 | 02:36 PM
bleueje17's Avatar
Interesting topic -
I have a 01 se 5spd and it takes off very strange. My buddy said it feels like a broken motor mount, but I am not sure. It is almost like the clutch plates are warped. If it helps - this has been like this since new. (now has 80k)
I am new here and appreciate any thoughts on this - It is the strangest 5spd I have ever driven.
Old May 3, 2005 | 02:50 PM
xlcrew's Avatar
I’m Back
i have someone who can press out the old ones and press in the new ones, just wondering if there were any tricks to getting the mounts out or not
Old May 3, 2005 | 03:31 PM
Larrio's Avatar
if you have a press its rather straight forward
Old May 3, 2005 | 03:33 PM
PoLo's Avatar
2-Wheelin it...
hehehehe....
xlcrew's Avatar
I’m Back
how do you guys support the motor when taken them out? use a jack, jack stands? that's pretty much the only advice that i need. thanks
Old May 3, 2005 | 04:02 PM
Larrio's Avatar
car on jack stands
piece of wood right where the engine and tranny meet up for somewhere stable and put the jack underneath that
Old May 3, 2005 | 08:02 PM
xlcrew's Avatar
I’m Back
how do you get to the bolt on the back motor mount? the shift linkage is in my way need help ASAP
Old May 3, 2005 | 08:43 PM
xlcrew's Avatar
I’m Back
need serious help here guys. i think i'm going to leave my car at my shop tonight and start again tomorrow after work, i hope i can get some answers. i got the front mount loosened up, and i just can't see to get to back mount in a way that i can get leverage. any opinions would be helpful. thanks in advanced and i hope to have it done tomorrow.
Old May 4, 2005 | 01:08 AM
Larrio's Avatar
take off the driver side wheel and splash guards, not the fenderwall stuff
take a 17mm socket with swivel attachment or wobblehead socket. Attached a long extension to a breaker bar or air/power tool. You can see the rear motor mount bolt like this.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
ballerchris510
Sep 23, 2015 08:46 PM
intimidator
Sep 5, 2015 07:23 PM
conansriver
Sep 3, 2015 06:38 AM
Lane
Jun 11, 2001 07:26 AM
