parking light bulb removal
Old May 4, 2005 | 02:56 PM
xxdean057xx's Avatar
im sure this has been talked about before but i cant find it anywhere, a lot of the links in the stickies are not even there anymore.
well i tried to change the freakin bulb but i couldnt remove the socket because of its location in such tight quarters........any links?????
Old May 4, 2005 | 04:17 PM
anyone??????
Old May 4, 2005 | 04:31 PM
skierxx5556's Avatar
i had trouble removing mine to get the one on the passenger side i took the tube for the washer fluid off and that made it easier and on the drivers side i had to loosen the bolts on the battery and move it to the side a little... you have to do a little pulling too but they do come out pretty easy...
Old May 4, 2005 | 11:46 PM
DJ2Max's Avatar
hrmmm... i just reached in there and gave it a twist.... i feel small.
Old May 5, 2005 | 12:11 AM
bigsherv's Avatar
i had trouble getting mine back on, but eventually it got back on.
Old May 5, 2005 | 08:37 AM
XGaSpAcHo
remove the headlight.
Old May 5, 2005 | 08:41 AM
nyautostyle's Avatar
remove the headlight? you should be able to reach it, ive replaced mine with blue bulbs before, but you need someone with skinny fingers to get to it. take your time too, ive dropped the bulbs in the engine bay before and it sucks haha
Old May 5, 2005 | 08:45 AM
TheBigDu's Avatar
Yeah, Nissan really could have left a little more room behind there. The weird angle also doesn't help.
Anyway, if you just squeeze your hand in there and ignore the pain of the sharp metal digging into your skin, you should be able to change it. It's definitely a b*tch, but it's doable. If you really can't fit your hand in there or find somebody else who can, then move the battery temporarily or something. The passenger side should be a little easier.
Old May 5, 2005 | 08:46 AM
XGaSpAcHo
sorry, i was thinking of the turn signal light. i forgot which one was on top for a second. but in any case, removing your headlight would work. you don't need to pull it out all the way just a little bit to give yourself more room to work in.
Old May 5, 2005 | 08:48 AM
TheBigDu's Avatar
It might be easier for those of you without DataDots. But not for me...
Old May 5, 2005 | 08:50 AM
XGaSpAcHo
you should still be able to pull it out a few inches. i know this because some ahole tried to steal my lights once but failed.
Old May 5, 2005 | 09:15 AM
CoolMax's Avatar
is invisible
Yeah, it's a ***** to get in but I was able to, but the light output doesn't seem level.
Old May 9, 2005 | 06:50 PM
lol, thanks a lot for all your help but my friends and myself tried to diconnect the bulbs but still got more pain then luck so i took it to a local nissan dealer and they changed it FOR 90.00!!!!!! i know the dealer is a rip off but i got lucky and didnt have to pay, my weanie friend bet me he could change the bulbs............... i won
Sport
Jul 3, 2017 05:40 PM
iflexsteel
Sep 15, 2015 03:37 AM
KristyKarina
Aug 23, 2015 09:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
