projector owners step in
Old May 10, 2005 | 03:50 PM
ornery1's Avatar
the projectors have a set of wires for parking lamps and a set for turn signal on my 2k i only have a set for park/turn since they are the same bulb. on projectors they are seperate....... how do i wire these things???????????????????????????????????????????? ???????
Old May 10, 2005 | 05:41 PM
ChromeSE5's Avatar
its plug and play. there is a socket coming from the car that goes into a socket that is attached to the bulb sockets in the headlamps.
Old May 10, 2005 | 06:01 PM
roll4life's Avatar
the set of wires is for the halos...which you gota splice into parking lights..i think thats what you mean..
Old May 10, 2005 | 07:17 PM
ornery1's Avatar
no. there is a 3 prong plug that goes to factory harness. then red/while for halos. then there are 2 sets for turn/park lamps
Old May 10, 2005 | 10:11 PM
ChromeSE5's Avatar
unplug the stock socket. There is another connector that comes from the stock socket to a plug that will match the ones coming from the projectors.
Old May 11, 2005 | 12:11 AM
tophersworld's Avatar
I just installed the projectors a few days ago. There is one plug for the Hi-Lo beams, One plug for the Turn sig/parking light and four wires, two red, two white that you tap into the side markers (white to black, red to red).
Also I found out afterwards if you have a 2000 you need to buy the 2002 grey plastic clips to replace the 2000 white clips to get them to fit right.
Old May 11, 2005 | 04:01 PM
ornery1's Avatar
what clips?? and since there are two seperate bulbs on the projectors how can i plug from the harness work parking/blinkers??? the park lams would flash.no?
Old May 11, 2005 | 07:58 PM
There should be 2 plugs on the back of the projectors, 1 for the ho-lo beams and 1 for the turn signal - parking lights. Maybe yours didn't come prewired like mine did.
I wired the red / white wires for the halos into the side marker lights (Not turn signal lights. The arrow ones on the side fenders.
The clips are twords the back bottom of the headlight. You will see them when you pop the old headlight out. Remove the two 10mm bolts and pull forward and up. They will pop put. Even though my Maxima is a 2000 I still had to buy 2002 clips (The grey ones)
All done. Any more questions?
Old May 11, 2005 | 08:39 PM
ChromeSE5's Avatar
how much were the clips?
Old May 11, 2005 | 09:03 PM
biggy8481's Avatar
this is good information to know... I was considering buying these and doing a retro.
Old May 11, 2005 | 09:41 PM
I paid $8.80 for the pair in So Cal dealership but I saw other have gotten them for a little more or less.
Old May 12, 2005 | 06:13 AM
ornery1's Avatar
tophersworld... thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
gigabyte
Jan 6, 2017 06:05 PM
D Mason
Jun 21, 2016 04:43 AM
bernyp
Oct 2, 2015 10:10 AM
