wheel barings bad?
wheel barings bad?
Anybody else have bad wheel barings?
i'm not sure if mine are bad but the other day i was driving on the freeway i felt a slight vibration. it felt like i was driving on a bumpy road but the road was completely smooth, but it was not enough vibration to make my steering wheel vibrate.
also, i can hear a slight grinding noise coming from the wheels
do you guys think its wheel barings?
how much to fix it?
can i fix it myself?
how much to fix it?
what kind of sound does a blown strut make? I do have stock suspension with 80k miles on it so if that is the problem time for full suspension?
the sound i'm hearing is like loose metal on metal ocassionally grinding and it only happens at certain speeds.
i don't think its a poorly balanced wheel because i've been on these tires and rims for 10k miles about and never felt this vibration before?
Thanks again.
Thanks again.
Thanks again.
Thanks again.
Originally Posted by gameover03
generally, u do feel a bad bearing..i replaced mine last week...u get the vibration at certain speeds
so assuming that it is struts, what is the best solution? should i get new springs and struts all around? or only new struts?
crap, i don't think its my shocks. i put my car up on jack stands today and i wiggled each one left and right and the front passenger side wiggles left and right but the driver side is fine. how do i fix this?? i'm pretty sure this is the vibration that i feel on the fwy
are wheel bearings covered under extended warranty?
I called multiple dealerships and asked if my wheel bearings are covered under the silver security plus warranty (100k powertrain warranty through Nissan) and none of them would give me a straight answer. They all respond telling me that I should bring the car in so that they can diagnose what the problem is, then figure out if my bearings are covered under warranty, but no chance i'm going to do that... I don't want to risk having to pay the diagnosis fee again for them to do nothing to solve my problem.
I'm a college student and I don't really have the extra money to pay a stupid dealership to do nothing. Anybody have suggestions of what I should do?
Also, heres a link to the wheel with what I think is a bad wheel bearing: video
Is there a possibility that this could be something other than a bad wheel bearing?
Thanks.
Thanks.
I have some of these symptoms as well. I'm going to have my front-end checked out by Nissan soon, b/c I know it's not the balance (had that checked 3 times), and I want it done right the first time. If Nissan screws up, I can go back and yell until they fix it.
I'm about 95% sure that a couple of guys have said in the past that wheel bearings were actually covered under their powertrain warranty. If you have the extended warranty, it'll definitely be covered. One of the many Jasons on here had all of his done at 60k miles. They were covered under his extended warranty.
thanks for the quick reply!
I'll probably bring my car in tomorrow morning. Did you look at the video clip? does yours do the same thing?
I also noticed while i had the car jacked up that this tire was worn down a little more than the others. I just bought these tires too...
Nice wheels though.
Do you have any other symptoms?
I have a '02 Max SE, and notice a slight grind/vibration when turning. It happens when I turn in either direction and at moderate to higher speeds. If I turn quite slowly, it doesn't make the noise. I also get feedback through the steering wheel and footboard. It's not harsh at all, just noticeable. Not the feel I expect from Nissan's flagship car. I suspect either wheel bearings or struts? Anyone else with similar symptoms?
A sign of bad wheel bearings can be HEARD if the wheel(s) make a "mum-mum" sound while driving. It's more noticeable at lower speed around 30-40 mph. Whichever side it's coming from, it's best to get it replaced ASAP, or then the other side will soon go bad. Some say it's best to do both at the same time on the same axle, but if you replace it fast enough, you shouldn't have any problems.
Originally Posted by Sammzway
How much did you pay to replace them and where did you replace it from? I need new bearing as well.
yea i would recommend that you bring it in to get it fixed. you should also do as much inspection that you can to confirm that its a bad wheel bearing or something else that might be covered under warranty.
i'm so relieved that they fixed it without any hesitation. the day i brought it in they acknowledged that there was something wrong with the bearing and the next day they started work on it and they just started work on the transmission and confirmed that everything would be covered under warranty. the service manager also told me that it should be ready by next week.
he also told me that i need to change my fan belts. anybody know how to change those?
$200 seems a bit steep. My local Nissan dealer charged me $129 to change the belts. Not sure why yours is $70 higher, but you may want to ask. If you don't want to take a shot at doing it yourself, you could also bring it somewhere private and see how much they'll charge.
Originally Posted by XGaSpAcHo
damn i outta go get mine checked out then. i have this LOUD scraping noise coming from the left rear wheel.
