Shocks & Intakes
Old May 20, 2001 | 08:12 AM
SS00MAXIMA's Avatar
Hieveryone,
I got a 2000 Maxima,and i want to install a intake and shocks for my GLE.Everyone should know the shocks for GLE is soft~~for grandpa and grandma.
I post this to ask advise from you guys,
wut intake system is better for maxima
stillen,K&N,or blitz(may not be able to install on it)?
AEM or place racing?
basically i know little about this brand,hope everyone tell me about them kindly.
shocks--->tokico , koni or anyoher brand
P.S.please add price beside it if you know,thanks!!1
Old May 20, 2001 | 08:18 AM
yongjun's Avatar
If you have the money go with Place Racing.
Or you can see how yo_its_ok's intake system works and get that.
It sounds promising.
If you are low on cash.
Try the OSCAI. The cost is about 40 bucks. The instruction are in the how to do and such.
Shocks if you have the money get Koni's. If not toikios will do
Old May 20, 2001 | 09:24 AM
punkdork's Avatar
I second this.
Old May 20, 2001 | 09:57 AM
UMD_MaxSE's Avatar
Got Bent?
I third it
Old May 20, 2001 | 11:47 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
I fourth this, but do check out the parts list for available parts for our Max.
Old May 20, 2001 | 06:57 PM
SS00MAXIMA's Avatar
Thanks for your help,
now i am wondering here,
wut model of shock would fit the car
coz i only find the following one on
the koni's homepage
can somebody tell me if this one would fit?
NISSAN Maxima Type QX, A32, 95-99
Front Rear
8641-1362 Sport 8040-1242 Sport
Special McPherson strut insert bolted into O.E. housing after cutting top and removing old internal parts.
Old May 20, 2001 | 07:24 PM
UMD_MaxSE's Avatar
Got Bent?
the koni's homepage
Front Rear
yes, those will fit....Kev is running those with his coilovers. You will need to cut the stock strut housing and bolt the Konis at the bottom of the housing. Or, you can get Tokicos since they are a straight bolt-on.
Old May 21, 2001 | 12:44 AM
SFMax20SE's Avatar
How about springs?
Which springs do you guys recommend. I have a 2001 AE SE. I don't want the car to be lowered more then 1.5-2 inches and possibly keep the same ride feel as stock. I know of Eibachs, but someone mentioned Ground Control. Also, do I need to get the front and rear sway bars, or can I just get the rear one? Thanks!
Old May 21, 2001 | 05:01 AM
UMD_MaxSE's Avatar
Got Bent?
Re: How about springs?
I think the FAQ sticky thread has springs with drops listed. Ground controls will let you adjust height. As for sway bars, there is no front sway bar....only a rear sway bar and a front strut tower brace. You don't have to get the RSB of FSTB, but they also make a huge difference.
Old May 21, 2001 | 08:21 AM
punkdork's Avatar
If you want a stock ride go with H&R springs. FSTB and RSB are only necessary if you want to increase handling performance. The RSB will make your ride a tad stiffer but in my opinion is well worth the trade off.
Old May 21, 2001 | 08:37 AM
psing23's Avatar
ye im putting on tokikos with eibachs... we'll see how that turns out... I also am getting the FSTB and RSB... wanna improve the handling as much as I can
Old May 21, 2001 | 08:50 PM
SFMax20SE's Avatar
Thanks for you advise guys! I did find what I wanted to know in the FAQ sticky, thanks UMD_MaxSE. I do want to enhance handling, so I will pick up the FSTB and RSB.
What is your take on intakes guys? Which one? I think I will go with the Cattman Y-Pipe... is this a good choice?
Old May 22, 2001 | 04:52 AM
UMD_MaxSE's Avatar
Got Bent?
Re: Re: How about springs?
intakes? three main choices: Underhood type (Stillen Hi-flow, JWT pop), PRCAI, and OSCAI. Look at the stickies and use search to find details on these. They have been discussed to death . Y-pipe is separate from the intake.....that is an exhaust bolt on.
Old May 22, 2001 | 06:16 AM
psing23's Avatar
Re: Re: Re: How about springs?
if you are considering an intake and you are not in a hurry i would wait to get the Maxximum Tuning intake... it looks like the best one out of the bunch and it definatly sounds amazing... It will be available in 4 to 6 weeks... you should expect the same results as a PRCAI except that you wont have to cut a hole in the side of your car and you wont have to worry about water ingestion into you engine...
Old May 22, 2001 | 06:44 AM
UMD_MaxSE's Avatar
Got Bent?
Re: Re: Re: Re: How about springs?
oh yeah....I forgot about that bad boy
Old May 22, 2001 | 01:27 PM
SFMax20SE's Avatar
Sorry, my bad... didn't make my question clear. That was actually 2 seperate questions.
Think I will wait for the Maxximum Tuning intake. Does anyone have information on this? Thanks.
For the Y-pipe, should I go with Stillen or Cattman?
Old May 22, 2001 | 01:33 PM
mbcp_tdogg's Avatar
Let's get a group deal in the works already.
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
maxima297
Sep 30, 2015 03:32 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
MichMaxFan
Sep 30, 2015 09:18 AM
