Replaced coils/plugs. Still have P1320??
Old Jun 30, 2008 | 08:22 PM
  #41
jdm01se's Avatar
It means catalytic converter.
Old Jun 30, 2008 | 08:30 PM
  #42
NmexMAX's Avatar
dot dot dot ...
Bad cat can be caused by a bad MAF or bad coils. So, these codes are at times hard to pinpoint.
Old Jul 1, 2008 | 07:01 AM
  #43
lavoiest's Avatar
thanks.....got lost on that one.
So essentially I may replace the MAF only to keep working my way down to the pre-Cat then to the other Cats?
Man this is a Big SUCK!
Old Jul 1, 2008 | 10:08 AM
  #44
NmexMAX's Avatar
dot dot dot ...
Well, I'd say MAF fist since it is the cheapest and easiest to replace.
Old Jul 5, 2008 | 07:50 AM
  #45
lavoiest's Avatar
I am going to do the MAF. The best price i found in town was 104 bucks. Is that a good price? This is for a stock unit.
Thanks Everyone.
Old Jul 7, 2008 | 06:04 PM
  #46
lavoiest's Avatar
ahhhhhhhhhhhhhhhhhhh
replaced the MAF.....guess what it's BACKKKKK
what the Fudge.
also noticed that the Intake Aircontrol IAC which at idle should be 9-15 is at 23-26 on mine? Does this indicate anything else?
and
EGR should be at 2.5v when warm and idling and mine is at 1.34v and never seemed to change with throttle/RPM, not sure if it should...
Help Please.... AND a big thanks for all the help and anything else you can add.
Starting to hate the Max......
Old Jul 7, 2008 | 06:29 PM
  #47
cefiro80's Avatar
+1
Old Jul 8, 2008 | 06:10 AM
  #48
NmexMAX's Avatar
dot dot dot ...
Maybe you need to get an ECU reflash to match the new MAF.
Old Jul 8, 2008 | 06:01 PM
  #49
lavoiest's Avatar
I have read both ways about the reprogram of ECU after a new MAF.
Is it normal that a reprogramming is needed?
Or is it normal that you should be able to plug in the new MAF and go?
One thing is for sure the car really does have it's power back with the new coils--plugs and MAF.
How much does a dealer charge to reprogram the ECU? I know it will vary but kind of looking for a range so I know if the Dealer is trying to charge too much.
Thanks everyone..
Old Jul 9, 2008 | 06:18 AM
  #50
NmexMAX's Avatar
dot dot dot ...
Only if symptoms still persist.
If all is fine, then, no, there is no reason.
Check into your IACV before going for the reflash.
Old Jul 9, 2008 | 04:10 PM
  #51
lavoiest's Avatar
thanks!
So amazing that one code covers so many parts.
Old Jul 21, 2008 | 07:16 PM
  #52
lavoiest's Avatar
The issue ended up being after market coils. I went back to OEM and code went away.
Long story...........ugh..
Old Jul 22, 2008 | 06:29 PM
  #53
AbiramBangla
I guess It .Cost You to be Smat!.. Help Plz
HI all .. Im new so plz dont take me wrong .. if im posting at the wrong section . cuz i dont have much option ..
have 02 maxima se. i know quite a bit abt car but i guess it wasnt enough. i felt my car was eating alot gas ... after opeing the hood to change the plug. i found valve cover gasket leak .. so replaced front and back valve cover gasket and plugs .. Plus .. i clean my TB .. which was a mistke .. i open the TB and open spry the whole thing .. put everything back on .. my ideal went up above 1000rpm oh god .. check egine light came on couldnt deal with it .. so took it to the dealer .. and they give me code .. .PO507 PO223 PO123 P1800 and quote me with $1400 guys i fall from the sky .. poor me what els could be done i agree to do the job .. it was .. replacesd TB chamber Assembly .. MAF sensor and Vias Sensor. REcalibrated ECM .. i have no idea abt these last 2 . ok now back on road no check engine light on .. but i feel something is not useuall .. the car runs fine .. when my foot at the gas paddel but when i step on break .. the rpm should go all the way down right .. but its seem like its going going down and bhoom jump up a little and then gose down .. i didnt notice that b4 i mess around with the car .im sure its not normal .. why the rmp will jump up a lil when ur foot on the break right ? so plz tell me what should i do now and what can be the problem .. by the way talking my car back to .. dealer tomorrow but still will like to know so plz help me knowing!
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
