Changed Filter now get Bee's in the Can Noise
Old Aug 7, 2005 | 04:47 PM
siren001's Avatar
Hey, I just changed the filter on my intake and now i get the bee's in the can noise. I check all wirring and connections and they are all tight any ideas how to get rid of it, sounds like i get turbo but no boost lol
Old Aug 7, 2005 | 04:51 PM
irish44j's Avatar
retired moderator
....changing the filter shouldn't have any effect on that....what y-pipe do you have?
Old Aug 7, 2005 | 04:55 PM
siren001's Avatar
stock, but straight pipe after that, no cat. but b-pipe and muffler,
Old Aug 7, 2005 | 05:42 PM
SoonerFan's Avatar
Cletus
thats not the same sound as "bees in a can" which you get with a y-pipe
Old Aug 7, 2005 | 07:24 PM
KLOOGY's Avatar
L33t BMW Drivah
maybe yoru filter is rattleing agains some part of the car
Old Aug 7, 2005 | 07:37 PM
Inspiron's Avatar
check if you dropped a screw or something into the filter
Old Aug 7, 2005 | 09:09 PM
siren001's Avatar
so screw, filter it tie wraped to the side because i noticed it hanged a little bit, its more of a whistle, at certain rpms
Old Aug 7, 2005 | 09:11 PM
Emaxxima's Avatar
u sure u closed the air box properly. My friends altima makes that sound all the time but he doesnt wana fix it , he likes it
Old Aug 7, 2005 | 09:19 PM
siren001's Avatar
I no more air box, I get K&N Cone Filter converted from Air Box to that.
Old Aug 7, 2005 | 09:28 PM
KCMOMaxima's Avatar
My Apexi intake makes the same noise, a whistle at around 2500 rpms, i dont think it is anything you need to worry about.
Old Aug 8, 2005 | 12:33 PM
BewstAdd1ct's Avatar
you just replaced the airbox with a cone filter, right?
Old Aug 8, 2005 | 12:52 PM
KCMOMaxima's Avatar
No I replaced the box with a berk intake and apexi cone filter, what kind of intake did you get?
Old Aug 8, 2005 | 01:03 PM
Gray305Max's Avatar
Opa-Locka Goon
Originally Posted by KCMOMaxima
My Apexi intake makes the same noise, a whistle at around 5000 rpms, i dont think it is anything you need to worry about.
My berk makes the same sound around 2-3k rpm so i think its just normal.
Old Aug 8, 2005 | 01:07 PM
SoonerFan's Avatar
Cletus
my stillen, berk, and GAB all made the sound. its the air getting sucked into the throttle body
Old Aug 8, 2005 | 02:56 PM
Puppetmaster's Avatar
and that's different from the bees-in-the-can sound you'd get from one of em older y-pipes...
Old Jul 4, 2006 | 02:53 PM
devINVISIBLE's Avatar
Does anyone know of a way to fix the whistling noise from my intake at certain rpms? I know it has nothing to do with my aftermarket air filter, as I have heard the whistle with the air filter off as well as the MAF manifold off. I believe the whistle comes from air going through a fan blade at a specific speed that makes a resonating sound at a perfect frequency to make that noise. I had originally thought it was something like a small leak/hole that air was trying to come from when I fully opened throttle.
Anyways... I was hoping that someone had thought a solution that would help reduce this noise... as the intake sounds great, but the whistle is obnoxious.
The Wizard
24
Oct 1, 2015 08:47 PM
iamute
Sep 20, 2015 05:22 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
sdotcarter
Sep 2, 2015 09:53 PM
