2002 guys with sunroof switch please step in..
I need a quick question from you guys..
I have a 2000 and the sunroof switch had a 1 touch and the sunroof goes back automatic. now I replace my dome light with the 2002 because it had the 2 dome lights and the sunglass holder incorp with it.
But the swtich I have for the 2002 doesnt seem like a 1 touch button? can any of you guys that have the 2002 verife..is it a 1 touch? it seems like theres 3 clicks? so it I set it all the way back does this mean it automaticly opens ?
the reason I ask is I never used that switch and now my old switch just dangles and doesnt like OEM at all. I didnt try the switch out in the 1st place because I was running late to work. if its a 1 touch then i'll be really happy cause my 2000 switch looks ghetto hanging there.
Thank You for your Replies.
the switch has 1 sliding button and one push button. the slidding button can go all the way back yes automaticly but it has wich u dont have to do is steps were u can open it alittle and alittle more and alittle more then fully open or like i said just slide it all the way back and it will open all the way.hope u understand that. # 2 button is to flip it up like a moon roof good luck i dont see y it shouldnt work try it cant hurt good luck.
i thought it did but im not sure...
okay i found it... its called 'resetting the memory', which to me meant calibration...
anyway, from the tilt position, press the tilt down switch and hold until at least 3 seconds after the roof has closed.
I've been doing this the hard way!!! Whenever I disconnect the battery, I've been pushing the tilt button numerous times to open the moonroof a 3" section at a time until it's fully open and then repeating that to close it-that seems to reset the slider...now I know for next time.
BobMax
08-15-2015 12:35 PM
yat70458
08-03-2015 01:16 PM
