New maf, smooth accelaration!
Old Aug 30, 2005 | 09:48 AM
  #41
Puppetmaster's Avatar
Originally Posted by NisMo-Max
how much is a New MAF?
The interweb is your friend:
http://www.courtesyparts.com/secondtier_a33.html
Old Aug 30, 2005 | 02:25 PM
  #42
JimmyH's Avatar
My MAF went bad a couple years ago. It was after I put in one of those K&N filters. I replaced with stock filter, had the dealer replace the MAF, they advanced the timing, and my 00 Max has run perfectly ever since. I need to time it again one of these days.
Old Aug 30, 2005 | 05:14 PM
  #43
NismoMaxm's Avatar
yeah. still people say get it reprogrammed and who can do that for. antyone who has the machine or do i need to pop the fuse somewhere??and i didnt know timing went hand in hand with intakes/MAF.
Old Aug 30, 2005 | 05:45 PM
  #44
max929's Avatar
I,m buying one friday with 6 coils from Dave B, (love that Guy)
Old Aug 30, 2005 | 05:53 PM
  #45
2000maxixam's Avatar
i have a 2000 maxima and i just replaced my maf and there was a noticeable difference because before it would die between 3-5000rpms and it worked changing it
Old Aug 31, 2005 | 01:01 PM
  #46
MrPoisse's Avatar
xxwarderxx: TSB #NTB02-051a says its 0.7hr to reprogram the ECM.
100$ is too much
Old Sep 1, 2005 | 02:47 AM
  #47
AxMaN23's Avatar
Yeah. I don't think I would pay a hundred. But got mine done at the stealership for 45 and some odd change . btw DaveB now has a little print out saying what ecu reprogram should be done. I wish I knew that on my last maf I ordered from him.
Old Sep 1, 2005 | 07:54 AM
  #48
NismoMaxm's Avatar
whats Dave Bs contact information guys??
Old Sep 1, 2005 | 08:07 AM
  #49
maniax's Avatar
i realized that when i first change the MAF sensor on my maxima....the car felt like it was on nitrous.....just so smooth and fast. This only lasted for a couple of days and then the car turned back to normal and drove like how it did before.
Same with my 4 cyclinder 96 camry. When I changed the exhaust flex pipe. The car felt so smooth and quiet like an electric car. Then it went back to normal after a week or so. =/
Old Sep 1, 2005 | 12:45 PM
  #50
Maximhuh's Avatar
OK Day 1 of new MAF - Car is running GREAT (smooth accel. + decel) and she holds idle like it's her job. If it goes back to the way it was before this in a couple of days like others' max's, Then I'm putting all my fireworks inside it and lighting them off. Thank you courtesy nissan for the new MAF - BUT it better keep on working.
W00T !
Old Sep 1, 2005 | 03:21 PM
  #51
ftlmax's Avatar
2002se 6spdmax
Does anyone have a set of headers for sale for a 2002max?
Old Sep 1, 2005 | 03:22 PM
  #52
What the heck does this have to do with MAFs?
Old Sep 1, 2005 | 03:23 PM
  #53
Its in the FAQs...
Old Sep 1, 2005 | 03:24 PM
  #54
NismoMaxm's Avatar
thanks puppetmaster. ill look there.
Old Sep 6, 2005 | 11:45 PM
  #55
AxMaN23's Avatar
Speaking of new mafs and how they felt. Anyone have a logical reason as to why a new maf would seem to add alot to the butt dyno but then after a week or so feel sluggish again. One thing I did notice at first was alot smoother shifting (A/T). But after a few weeks it just didn't have that get up and go like it did when I first threw the maf in, Since then I banged my head on trying to figure out why it would change? any input would be great. The only Idea I have is that it was running rich with the new one until it adjusted to it.
Old Sep 8, 2005 | 11:29 AM
  #56
sontakke's Avatar
This makes sense. If old MAF was causing it to run lean, the computer had adjusted the parameters such that it was trying to add extra fuel for the amount of air that it was seeing coming in. But because of bad MAF, it was seeing less air than the one going in the combustion chamber. With new MAF, computer got correct mass air reading which will now result in extra fuel because of the heavy positive long term fuel trim value. Eventually, the computer will trim it back but until that time you will have great acceleration at the cost of running rich.
This would hold true if you were getting P0171 types of fuel injection lean
mixture MIL code. When you get those errors, your LTFT would over 30%
Does anybody sell only the sensor rather than the whole assembly? It should be cheaper that way, correct?
- Vikas
Old Sep 9, 2005 | 07:53 PM
  #57
AxMaN23's Avatar
I think you can get the sensor by it self but I would just call DaveB, I got mine overnited for 100ish (from Texas to North Dakota). Also I have read that you should change out the whole tube and sensor. I don't know why but I think it might be that maybe they are tuned to the tube that they are sent in (just a theory).
TallTom
57
Oct 14, 2025 05:16 PM
Mar 12, 2020 12:06 AM
TKHanson
Nov 24, 2018 01:39 AM
-ReLLiK-
Apr 29, 2016 06:25 PM
dcardello
Sep 3, 2015 11:44 PM
