Will a custom STRAIGHT B-pipe with stock muffler be too loud?
I keep seeing threads or references to various aftermakret B-pipes for the 5+5.5gen cars. But since the B-pipe is just a simple pipe with a small resonator on it, won't one from a muffler shop be just as good (mandrel bent)? If so, how much do you guys expect a custom bi-pipe will cost? And if I was going for a straight pipe, with no resonator, will it be too loud with a stock muffler? My reasoning is that a straight pipe will definitely flow better than a resonated one, and probably will increase the tone of the stock muffler too. Opinions?
I agree with your assumptions. I have the resonated B-pipe from LSS (Budget) Exhaust with a stock rear muffler. They told me the non-resonated (less expensive) B-pipe would be too loud. Well, after putting on the more expensive resonated B-pipe I wish I got the non-resonated (straight) B-pipe. My stock exhaust sounds slightly throatier at idle up to about 2500rpm but above that you can't tell. Oh well. I'd go with a straight B-pipe if that's all you're changing in your exhaust. If you change anything else (headers, y-pipe, rear section) I believe it may get a little loud, just an educated guess. Just my 2 cents, hope that helps.
Originally Posted by Kevlo911
A custom Mandrel bent Bpipe will be just fine. Use a Dynomax Glasspack as a resonator. It is only 30 bucks and has a Perforted core.
For Comparison:
I ran with cattman headers, test pipe, cattman b-pipe (with a huge resonator) and the stock muffler....I did it just to see how loud it was....to me it was damn quiet for the performance gains u get....to me it felt a little bit louder than stock, being the loudest at around 3k....after that, the intake roars over everything....
to answer your original question....I'm not sure how loud a bpipe with no resonator will sound....but I bet it won't sound much louder than stock...the 5th gen muffler does a great job of keeping things quiet...
Originally Posted by Bobo
A test pipe is illegal and you won't pass emissions testing without the catalytic converter. If I was going to buy a B-pipe I would get it with a resonator.
I have a Budget stainless steel y-pipe presently.
i ran mine for three days without the resonator with an aftermarket b pipe that i had with the resonator first. then i hit a 2x4 and had to get the b pipe fixed. i had them pull out the resonator and to let you know it sounded like ***. it wasn't loud, but really raspy and gross. i would of rather driven my friends integra with it's fart pipe vs driving my car with that. it took me two days and i bought another cat back that i found for a great price and got rid of the non resonated b pipe. right now i have an 18" glasspack for my resonator. resonators dont hurt the flow of the exhaust so please do yourself a favor and put one in. and yes a custom made bpipe will do just fine. that's the way my is and it's mandrel bends.
W/o a resonator, it might sound a lil bit too raspy. For $30 bucks, you might as well get a resonator put on.
Not sure if it related to the 3.5L ...but on a 3/0L, I had a custom B pipe w/o resontaor and a
straight thru magnaflow muffler, and you could barely tell there was any exhasut modifications at all .... But that all changed with a y-pipe install.
So, if you plan on installing a y-pipe or headers in the future, get a resonator ... you'll thank yourself you did.
Logic would seem to point in this direction as well.
straight thru magnaflow muffler, and you could barely tell there was any exhasut modifications at all .... But that all changed with a y-pipe install.So, if you plan on installing a y-pipe or headers in the future, get a resonator ... you'll thank yourself you did.
carid
Sep 17, 2015 05:00 AM
