Automatic Window Problem
Old May 5, 2014 | 07:12 PM
  #81
Les7311's Avatar
False alarm. .. my 05 doesn't have the nipple reset button. .. Pull door panel off and still no luck. ..
Anymore suggestions?
Old May 6, 2014 | 08:06 AM
  #82
Montego Murph's Avatar
You mentioned you have a 2005... a quick googly search showed me this:
http://nissanhelp.com/diy/maxima/pro..._procedure.php
Old May 6, 2014 | 12:53 PM
  #83
Les7311's Avatar
I must have the "other version" of a maxima door.
that same location has a "strong-adhesive tape" over a hole the size of 2 quarters, and nothing there. Even had help looking for nipple - nada, nein, nothing!!
Will check again. Great find though.
Old Jul 20, 2021 | 08:45 AM
  #84
rakebquraishi's Avatar
Originally Posted by MaxDom03
Hey guys, I've been having some issues with my passenger side automatic window control. When I hit auto and let it go up it reaches the top, then goes back down 1/4 of the way. It doesnt fall, but rather the motor(?) brings it down. If I hold the button up while closing it, it stays up.
Has anyone had this problem before? Do I need a new reglulator/motor?
I have had the same issue. It is just the power window motor in your door that needs to be reset. The reason the window goes up and then down is because it is a safety feature in case someone has their hand in the way. The safety boundaries are not set so its malfunctioning. A reset of the motor is all that is required. The guys at the workshop just push a button on the motor for a few seconds and release it along with a small procedure. The motor can be accessed by opening up the interior door panel. My guy charges me around $50 for the job. Hope this helps.
Old Jul 20, 2021 | 10:17 AM
  #85
Prophecy99's Avatar
thanks for this rakebquraishi, i have this issues as well.
The Frye
Feb 3, 2019 08:34 AM
thenewguyy
Sep 12, 2015 11:12 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
