How difficult is it to replace ignition coil for cylinder #2?
Old Sep 7, 2005 | 07:31 PM
ajahearn's Avatar
I feel reasonably competent working doing maintenance items (e.g. oil change,
pad change, etc.) and slightly more ambitious stuff (e.g. installed RSB, installed and removed Injen intake, etc.). However I avoid the complicated stuff (e.g. UDP, etc.).
I have the ESM and its not clear what section describes replacing an ignition coil. It seems like its just a matter of 1) removing the plastic engine cover, 2) identify the right coil, 3) replace, 4) reverse 2 and 1. I'm guessing that the battery cable should be removed but I'm not sure about anything else.
Any directions? How do identify the #2 cylinder coil?
Old Sep 7, 2005 | 07:46 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
owners manual will show you the engine diagram....
Old Sep 7, 2005 | 08:37 PM
Puppetmaster's Avatar
Here's a write-up on how to replace the coils on an 02 from GregP:
http://www.greghome.com/Greg's%20Garage/2002MaxSE/SparkPlugReplacement.htm
Old Sep 7, 2005 | 09:01 PM
ajahearn's Avatar
Thanks for the link. I owe Greg a few times over now (I used his Stillen RSB write up as well as his Injen install).
Old Sep 8, 2005 | 06:15 AM
No problem... let us know how it works out for ya...
vingodine
45
May 21, 2016 12:46 PM
sake1bs
Sep 19, 2015 09:32 PM
iflexsteel
Sep 15, 2015 03:37 AM
vanebecker
Aug 17, 2015 08:24 PM
maxima297
Aug 3, 2015 12:50 PM
