Helios mini Install
Old Sep 8, 2005 | 04:05 AM
big_bogus's Avatar
Helios mini Install
Just received my kit from Maximabest. Does anyone have picts or ideas for the fog light install? The kit is suppose to be Plun-n-Play, but I believe that would require leaving the protective cap off, which I don't want to do. I hate to have to cut and remove the OEM wires, but.....
Old Sep 8, 2005 | 05:21 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
What do the instructions say? There should just be a wiring harness on the ballast which will plug right into the OEM harness.
Old Sep 8, 2005 | 05:24 AM
big_bogus's Avatar
Correct
But I am referring to the bulb side. Is it necessary to modify the back of the Fog housing?
Old Sep 8, 2005 | 06:59 AM
In instances of a full size bulb, the fog light housing does need some minor modification...however, your title leads me to believe that you have a 'mini' bulb?
Old Sep 8, 2005 | 07:24 AM
big_bogus's Avatar
Yes the mini H3.
Old Sep 8, 2005 | 05:10 PM
Yes the mini H3.
You should be fine, then...
Old Sep 8, 2005 | 07:54 PM
Park2670's Avatar
The Ultimate Driving Machine
I actually cut and soldered the wires back together and used the factory dust cap with no modifications to the cap. All stays dry with no problems
Old Sep 9, 2005 | 04:56 AM
big_bogus's Avatar
Thanks. That was what I was wondering. I hate to do it, but such is life.
Old Sep 9, 2005 | 06:24 AM
NISMAX03's Avatar
Here are a couple of pics of where I mounted the ballast and ignitor behind the front bumper. I also had to cut the wires to keep the protective cap.
Old Sep 9, 2005 | 06:30 AM
big_bogus's Avatar
Thanks. I've seen your pics. Nice!! Do you have any pics of the protective cap with the new wires run through it?
Old Sep 9, 2005 | 06:38 AM
NISMAX03's Avatar
I'll take some pics and post them shortly.
Old Sep 9, 2005 | 05:00 PM
big_bogus's Avatar
I wish I would have looked at your pics more closely. I didn't want to mount anything to the bumper. The wife has screwd it up an it needs replaced. So I mounted the 2 boxes to eachother then mounted the AL frame to the lower tow hook by one of the mounting bolts. Not as nice as yours, but functional.
For the Fog Dust cap. I ended up removing the OEM wires and rubber plug and fishing the Helios wires out that hole and siliconing the hole up. Not the best solution, but fool proof.
The final result is the Fogs are georgeous!! But they do not match the factory headlight HIDs. Maybe I will buy new Bulbs in the future for them to match.
Thanks!!
Old Sep 9, 2005 | 10:38 PM
umnitza's Avatar
Former Sponsor
Sorry to bother, we have 8 sets of these.
We will sell them off for $230 a set. All Mini.
All via paypal only - paypal@Umnitza.com - all Prolumen.
Old Sep 12, 2005 | 01:36 PM
808SE's Avatar
Yeah that "plug and play" is a load of crap. Anytime cutting and soldering is required, the kit is not "plug and play."
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
