Squealing sound when I turn the wheel to the right
Old Oct 9, 2005 | 07:06 PM
00MaxSE's Avatar
Pointy Elbows
I've been noticing when I start the car and turn the wheel all the way to the right it, it makes squealing sounds. Sounds like what a belt squeal would sound like. Any idea?
Old Oct 9, 2005 | 07:16 PM
irish44j's Avatar
retired moderator
power steering belt may be slipping. Tighten it up a bit and/or use some belt dressing.
Old Oct 9, 2005 | 07:17 PM
99 SE-L
Wheel bearing/spring .....
Old Oct 9, 2005 | 07:18 PM
irish44j's Avatar
retired moderator
other thing it could be (duh) is the end of the steering bump stop has worn through (its plastic) and is rubbing metal to metal on the lower wishbone of the suspention (where it "bumps"). I had this problem. you can get new bump stops for like $1 at the dealer.
Old Oct 10, 2005 | 12:10 PM
00MaxSE's Avatar
Pointy Elbows
Thanks guys. I'll look into it. I don't think it's the wheel bearing because it makes this noise when the car is running, but not moving.
Old Oct 12, 2005 | 02:45 PM
BewstAdd1ct's Avatar
which would rule out the bump stop too.
mine dies it when its cold, if i take it to lock real quick, the belt will chirp... no big deal.
do NOT use belt dressing on a belt. unless its a show car. ive seen that **** cause wayyy too many problems.
g/l
trasmadean
Feb 1, 2017 08:20 PM
02PearlSE
Oct 7, 2015 02:12 AM
Andy29
Aug 31, 2015 01:59 PM
official_style
Aug 29, 2015 10:10 AM
follyburr
Aug 7, 2015 09:50 PM
