6spd Fluid Capacity
Old Dec 31, 2005 | 06:28 PM
BumpnMaxima's Avatar
6spd Fluid Capacity
I have read in places on here, specifically the HOWTO on changing to redline that the trans takes 2.5 quarts. he also mentions to fill till its at the fill hole level. well i went to the dealer to buy trans fluid and he said it needed 3.5 quarts. so i bought 4 and the trans took the full 3.5 quarts before it started coming back outta the fill hole. whats the deal here
Old Dec 31, 2005 | 09:12 PM
steven88's Avatar
Need A Light?
something is wrong...my 6spd starts pouring out of the fill hole towards the end of my 3rd qt....thats around 2.75qts when it starts to come out....i also did a tranny fluid change for my homie's 6spd...same deal...i dunno why yers is different....
Old Dec 31, 2005 | 11:35 PM
is it gunna hurt anything having about 1 quart extra in there? i drove it breifly and it was fine. maybe its cause i had the car jacked up?
Old Jan 1, 2006 | 05:09 AM
Puppetmaster's Avatar
I used a little over 2.5 qts and did not have the car jacked up.
Old Jan 1, 2006 | 01:45 PM
housecor's Avatar
If only the front of the car is lifted it will hold more before pouring out of the fill hole due to the angle. To assure a proper level, you should try to fill it on solid ground. However, I doubt a little extra fluid will hurt anything since there's plenty of room for it to just sit in the case.
Old Jan 1, 2006 | 02:13 PM
LA02MAX's Avatar
you probably just didn't notice it until then...i put 3 full quarts in mine, but it was draining out of the fill hole for quite a while afterwards because i just wasn't paying attention...
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
fastcarny
Oct 12, 2015 07:06 AM
Need help
23
Oct 2, 2015 08:56 AM
220k+ A32
Sep 23, 2015 03:38 PM
