Squeaky Belt
Old Jan 17, 2006 | 03:15 PM
TPenguin's Avatar
Got Penguin?
Squeaky Belt
Well guys i just installed a new alternator and decided to replace the Drive Belt as well... Only one problem though, the belt squeaks like no other! After its warms up it goes away. I have tried loosening and tightening it and nothing... Anyone have any clues? My only thought is that its not tight enough or that you have to lube the tensoner bolt... any help would be great guys!
Old Jan 17, 2006 | 06:11 PM
5thgenmaxima's Avatar
Never heard of having to lube any bolts to prevent squeeking....It's hard to check the proper tensioner from the top side because of the small amount of belt between pulleys....Go from underneath from the crankshaft to the AC pump (IIRC) there should be about a foot of belt and you should be able to flex it about 1/4 of a turn........
Buy some belt dressing...If you spray it on the belt and it goes away, it's brobably a tension issue.....If it doesn't go away its probably the idler pulley.
Old Feb 1, 2006 | 10:08 PM
JCTPM's Avatar
I'm gonna do a belt change over the weekend. I was doing a oil change last week and inspected the belts. They were all cracked, so I ordered new belts. There wasn't any DIY instructions in the owners manual, so can someone post up a DIY for both belt changes. I searched for this topic already, but I only got full Underdrive Pulley installs.Thanks.
Old Feb 2, 2006 | 06:17 AM
igzy's Avatar
I Know Kwaliti
To install an UDP you will need to remove the belts
Old Feb 2, 2006 | 06:31 AM
igzy's Avatar
I Know Kwaliti
Also try this... http://forums.maxima.org/showthread.php?t=308647
Old Feb 2, 2006 | 08:03 AM
JCTPM's Avatar
Thanks ! That writeup will help me immensely.
Old Feb 2, 2006 | 08:41 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
you need to put the belt and adjust it enough so you can turn the car on and adjust it until the noise goes away.. I did it this way and it worked for me....
05' MaximaMan
Oct 8, 2017 06:36 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
