O2 sensor prob P0138 2k Max
Old Jan 18, 2006 | 11:22 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
so my parents 00 Max has been getting some pretty crappy gas mileage recently. About 200-210 on a tank. 50/50 freeway/city driving. Seemed like it was getting a bit slugish but wasnt sure. Yesterday i got code P0138. My scanner says bank 1 sensor 2. Can someone tell me which O2 that is so i dont have to figure it out myself?? heheh thanks!
Old Jan 18, 2006 | 03:59 PM
Puppetmaster's Avatar
The location depends on if the 2000 is CALI or FED spec. And since you're in CA, I assume that you're supposed to have a CALI spec for smog purposes. In that case, the sensor is the one on the front of the y-pipe.
See here for more details:
http://maxima.theowensfamily.com/tsb/NTB02-051a.pdf
Old Jan 19, 2006 | 05:29 AM
Epacy's Avatar
Unsuccesful STL Coordinator
You're lucky. That one is easy to get to. 15 minute job.
Old Jan 19, 2006 | 06:43 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
the only thing i am wondering is that secondary o2 sensors are used to monitor only and have no ability to alter a/f. a bad secondary should have no effect on a/f therefore no change in mileage. i had one bad secondary o2 sensor and the other was disconnected after my header install for a few weeks with no change in gas mileage.
Old Jan 19, 2006 | 07:19 AM
Good point, I completely overlooked that. IIRC, the only way the secondaries can be used to influence AF is if the primaries were shot too. Is that a possibility here?
Old Jan 19, 2006 | 07:45 AM
sloppymax's Avatar
i have heard of them assisting only in the situation you mentioned. i would just assume though that if a primary was dead then the code would have been pulled. i would also assume the secondary would only step in if the primary was dead and not just on its way out.
Old Jan 19, 2006 | 07:49 AM
Epacy's Avatar
You should have codes then if you removed your secondary, irregardless of your current code.
bbsitum
Sep 6, 2019 07:31 PM
220k+ A32
Sep 11, 2015 02:18 AM
dcardello
Sep 3, 2015 11:44 PM
