annoying acceleration noise
Old Mar 8, 2006 | 05:09 AM
JaKillz2's Avatar
whenever accelerated, no matter what the throttle position, as long as its >about 4000 rpm, I have a prominant sputter/bubbly noise. It is noticable outside and makes the engine sound like crap. I know there is supposed to be some noise similar to this when under strain or going up a hill for example, and I had something similar in my old 88 cadillac whenever accelerating. It occurs in every gear especially when a higher gear is used in a low rpm situation for whatever reason, (say 2cd when turning into a driveway and accelerating a lil, it would drop to about 1500 due to the speed) I use 93 octane, dont know if the previous owner did which would have been about 70k miles. I dont believe the spark plugs have been changed, now about 80k.
It's just too MUCH and too LOUD to be normal IMO and the car just doesnt seem to be as spunky as it should be with the sound occuring
Old Mar 8, 2006 | 09:45 AM
trigger005's Avatar
Have you tried Seafoam the miracle $6 solution? It sounds like maybe some pipe is clogged and in your car, if so that will hopefully clear it up.
Old Mar 8, 2006 | 09:50 AM
qballjr13's Avatar
Is it the typical spark knock??
Old Mar 8, 2006 | 12:17 PM
JaKillz2's Avatar
thats what im thinking qball.. i was planning to change them soon anyways.. we'll see
Old Mar 8, 2006 | 12:21 PM
Maxima-Ness's Avatar
dont know if this helps, but ive had a bubbling noise upon acceleration and ive been told I need to bleed the heater core. Story goes, that theres probably air trapped inside. Dunno if this is even near what youre hearing, but thats what I have been told.
Old Mar 8, 2006 | 03:29 PM
JaKillz2's Avatar
what if your heater isnt running?
could oil have anything to do with this? I use quaker state peak performance 5/30
Old Mar 8, 2006 | 05:58 PM
It happens to me all throughout the year, and since i dont use the heat in the summer....
Old Mar 8, 2006 | 06:01 PM
JaKillz2's Avatar
so how hard is it to bleed a heater core?
Old Mar 8, 2006 | 06:26 PM
carsarecool's Avatar
Oil probly doesnt have anything to do with that problem but ive heard quaker state isnt exactly the highest quality, its actually right in par with pennzoil(parent companies)
Old Mar 8, 2006 | 06:46 PM
JaKillz2's Avatar
k well im doin an oil change anyways any day now, and plugs so we'll see..
Old Mar 8, 2006 | 07:44 PM
Im sure someone on here knows. I was told how to do it like months ago, but that memory has been replaced by a bunch of college junk...
Old Mar 8, 2006 | 08:17 PM
i30ish's Avatar
this sounds similar to my problem at around 2k rpm in 2 or 3d gear. All i have to do is add some gas and the rattle goes away.
Old Mar 13, 2006 | 07:48 PM
MAXIMA6259's Avatar
spark plug
my old car did that, change the plugs
Old Mar 13, 2006 | 08:44 PM
Originally Posted by MAXIMA6259
...change the plugs
what?
no, seriously.....
....what??????
Old Mar 26, 2006 | 07:48 AM
Supreme Allah's Avatar
I doubt that's the problem. I have the noise he's talking about, and my plugs were replaced with my coils about 2k miles ago.
It seems to happen with cars as they age. Very common, I've always wondered what caused it. It's annoying but since it happens in a relatively narrow power bandwidth it's easy to drive around it most times.
Old Mar 26, 2006 | 08:15 AM
JaKillz2's Avatar
Ya I had changed the plugs, and seafoamed both the manifold and crankcase to clean up in case it was maybe a dirty lifter or valve. (that happened a lot in my old 88 car) But it is still very much there and the car has 80k and thats really NOT that much compared to 150k
Old Mar 26, 2006 | 11:24 AM
sascuderi's Avatar
Could it be a leak in the exaust system?
Old Mar 26, 2006 | 11:48 AM
JaKillz2's Avatar
hmm.. interesting, I've never heard of that
1.) How would this make that noise?
2.) How would I check or "analyze" it?
It is definately sounds like it's coming from the engine bay though. However I just found this thread
http://forums.maxima.org/showthread.php?t=373701
which sounds SIMILAR at least to my problem except I don't really understand the studs part. How could bolts make a rattling noise upon acceleration?
Old Mar 26, 2006 | 09:34 PM
hjaveri's Avatar
I had a similar problem with my old Maxima. Never knew what it was.
Old Mar 26, 2006 | 09:37 PM
MaxBoost925's Avatar
Drug Money
Originally Posted by Maxima-Ness
what?
no, seriously.....
....what??????
change yer buttplug
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
D Mason
Jun 21, 2016 04:43 AM
mpbclutch33
Dec 26, 2015 11:11 AM
Need help
23
Oct 2, 2015 08:56 AM
