HELP 5th GEN FOG REPLACEMENT
Old Mar 16, 2006 | 01:41 PM
pashe's Avatar
Does anyone have the write up for the 5th Gen fog replacement. The link in the how to thread does not work.
Old Mar 16, 2006 | 02:47 PM
embraer's Avatar
Try this:
http://www.innerbean.com/housecor/piaa_fogs.html
Old Mar 16, 2006 | 07:13 PM
pashe's Avatar
Thanks a million
Old Mar 17, 2006 | 11:25 AM
boondoxmax's Avatar
I replaced both my bulbs over the weekend. What a PITA of a job.. My hands just aren't made to squeeze into small spaces........WTF was nissan thinking with this design..
Old Mar 17, 2006 | 11:34 AM
spiromax's Avatar
Seoul Man
Do you really have to ask? They were thinking, "Let's make this part dealer-serviceable so that owners won't try to do it themselves."
Old Mar 20, 2006 | 11:12 AM
pashe's Avatar
I tried replacing mine y'day and I couldn't get to it (I have a 5th gen not a 5.5). The plastics underneath the car are a real pain. The easiest way would be to cut them off, but before I do that are there any shortcuts? I can't handle another day of one eyedness
Old Mar 20, 2006 | 11:19 AM
naxray's Avatar
Remove the pop connectors and the bolt on the plastic cover to gain access - no need to cut anything.
check out this useful link:
http://www.moodym.com/maxima/tech/foglight.html
Old Mar 20, 2006 | 02:40 PM
reflectionz's Avatar
I had a nightmare of a time with those 2
Old Mar 20, 2006 | 08:15 PM
Anethema's Avatar
fog light replacment
I just removed my headlight housing and got to them very easy.
Old Mar 21, 2006 | 06:51 AM
MAXRB8's Avatar
Just replaced my cracked ones yesterday, bought a "chip no more" clear plastic film set to cover the lens so we'll see how they hold up. One screw, one bolt and one clip to remove each lower panel cover, then two 10mm nuts holding the fog light unit in place, not really a big deal.
Old Mar 21, 2006 | 12:01 PM
boondoxmax's Avatar
On the 5.5 gen theres 2 screws and 1 clip to remove the black plastic, but one screw on each side was rusted tight so i had to spray so Wd40 on it to soak before it would come off. The biggest was that damn clip you have to push in to release the plug. Yeah I see why nissan puts see dealer in the owners manual about bulb replacement
Old Feb 17, 2010 | 12:34 PM
b15philly's Avatar
I know I am bumping this thread from a few years back but I cant for the h##L of me get the the harness un-clipped. I got the bolts off and the light is hanging out of the front, but I cant seem the get the harness un-clipped, any secrets? I have tried pushing the tab down and every which way with my finger and small screw driver.
Also, I know PIAA is probably the best bulb brand and I know I need a H3 bulb, but what is the best wattage for a yellow bulb? will these work?
http://cgi.ebay.com/ebaymotors/PIAA-...Q5fAccessories
Old Feb 17, 2010 | 12:49 PM
vball_max's Avatar
That clip really is a pain in the ****.....well...actually a pain in the fingers......
I usually press the tab down with a small flathead screwdriver. And the only really secret is to wiggle it back and forth as you pull.
55w is the standard bulb wattage for the fogs. But if you buy those for $60, you are nuts. You can find much better values out there. Check out the Luminics yellow bulbs. They should be about half the price.
Check here: http://www.optionsauto.com/products.asp?dept=346
The PIAA ions are $36.00 + shipping.
Old Feb 17, 2010 | 12:53 PM
b15philly's Avatar
Thanks for the quick reply, the PIAA's are crazy expensive ill check out that link.
Old Feb 17, 2010 | 01:00 PM
Rochester's Avatar
kgallerie is right - a very small, flat-head screwdriver. The clip that you push against is ribbed. Push down with the screwdriver, then while pushing down, push away from the clip connector and they'll come apart.
Take your time. Once you figure it out, you'll be able to take those fog lenses out with your eyes closed.
Old Feb 17, 2010 | 01:16 PM
b15philly's Avatar
Would you guys go with yellow's or the extreme white's, I knows its my decision but just looking to hear other opinions.
Old Feb 17, 2010 | 10:59 PM
KBCobra's Avatar
I would go yellow. I have the yellow fog lenses on mine but I regret getting the actual yellow lens. I should have bought the clear lens with a yellow bulb. Yellow always looks more stylish than plain ol' white
CRizz
41
Jun 7, 2021 05:42 AM
Finkle
Sep 27, 2015 09:53 PM
ef9
Aug 27, 2015 07:21 AM
Samedi
Aug 12, 2015 01:54 AM
MikesChevelle
Aug 6, 2015 11:36 AM
