Rear rotor removal...feels like it's welded on
Ok so after two hours of hammering the rear rotor, PB Blaster, probably pissing off my neighbors, and a trip to autozone...I was still unable to get them off. I saw two little screw holes which I am sure are used for getting these buggers off. Can anyone recommend the screw size or alternative methods to getting these rotors off?
Use those threaded holes for what they were intended for. It will definitely push the rotor out towards you. It is probably a 1.25 fine thread count. Just go get some bolts of differing diameters and see which one works.
![Werd](https://maxima.org/forums/images/smilies/werd.gif)
mine didnt have the bolts screw holes.. I did mine yesterday and i couldnt get it off ethier.. Took it to a guy i know he knocked the lving life out of it... All it is; RUST and plus the parking brakes behind the rotor..
If yours has the holes, use them.....If you have a local harbor freight go there. They sell a tool you put on those screws and put force on it. You then hammer the "screw driver" and it helps the screws turn. Those screws will most likely strip unless you use the tool...
Also anti-seize is your friend when reinstalling.
EDIT: here's a pic of the tool you will most likely need. http://www.harborfreight.com/cpi/cta...emnumber=46978
They will come off with ease, with one of these.
Well asuming that your wheel and lugnuts are off, and there are nothing holding it on but rust.. use some PB blaster and let it sit a minute or two..then using a rubber hammer tap it (not to hard) all around.. I've done it before (not on my Maxima)..I TAKE NO RESPONSIBILITY if you brake something or hurt any one...............G'LUCK!
