Another stupid question..
Old Apr 23, 2006 | 04:52 AM
Aeiceman's Avatar
To lower a 2000 Max, do I have to replace the struts or just the springs?
Old Apr 23, 2006 | 06:33 AM
phong's Avatar
Technically, the ride height is controlled only by the springs but it's recommended that you replace them together - the new struts will be specifically valved to match the new spring rates.
Not only that, but it just makes sense to replace the struts while you've got everything apart. If you've never replaced them on your 2000, the factory ones are probably shot.
Old Apr 23, 2006 | 10:22 AM
frankd121's Avatar
I would also go with adjustable struts to better control the ride. Some of the springs are much stiffer than stock and most non-adjustable aftermarket struts don't provide enough dampening - making the ride seem wierd. You'll be able to tune the strut to match the spring rate with the adjustable strut.
CorollaULEV
30
Aug 9, 2021 08:11 PM
pears
Sep 18, 2015 05:25 AM
A32goldylocks
Sep 16, 2015 01:33 PM
carlosvq30
Aug 17, 2015 11:32 AM
edsmax
Nov 10, 2000 05:22 PM
