what does an Immobilizer immobilize?
Old May 3, 2006 | 12:46 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
what exactly does the immobilizer immobilize? is it the fuel pump or ignition? basically whats going on is we're doing a 6speed conversion for a 5.5gen. Car cranks over but it doesnt start. Its the orginal automatic ECU, we did not change the ECU yet. thanks for any help.
Old May 3, 2006 | 01:10 PM
Larrio's Avatar
The Definitive AE Master
Supposedly the fuel pump
"As the ignition is turned, the reader is activated and sends out a wireless signal to the transponder. The signal powers up the transponder's capacitor, allowing it to transmit its unique code back to the reader. The code is then sent to the control module, which compares it to the code stored in its memory. If the two codes match, and the appropriate additional security challenges are passed (depending upon the type of transponder featured in the immobilizer system), the control module enables the engine's computer or the fuel pump relays. If the codes do not match, an alarm indicator will show and the engine will not start, rendering the vehicle impossible to drive until the proper key is inserted for ignition."
http://www.ti.com/rfid/docs/news/new...06-01-99.shtml
Old May 3, 2006 | 01:30 PM
Turbo95Max's Avatar
so it could actually be fuel or ignition? or both...meaning the car would or could still crank but not start up....crap
Old May 3, 2006 | 01:35 PM
ColdSHO's Avatar
it is the fuel pump, most cars are like that now-a-days.
Old May 3, 2006 | 02:02 PM
MAXRB8's Avatar
Not quite right, they are not connect directly and only to the fuel pump, in a nutshell they are connected to a control module in the ECM which in turn controls igintion and fuel circuits.
Old May 3, 2006 | 02:05 PM
Larrio's Avatar
you might have to find a 6spd ECU and have technosquare copy the immobilizer info over.
Old May 3, 2006 | 08:15 PM
getbigtony's Avatar
you could just test for it
turn ur key to start; if you hear a lil sound like fuel goin to your injectors, you have fuel
test ur ignition by getting spark plug tester; then crank and look for spark
Old May 3, 2006 | 08:19 PM
Turbo95Max's Avatar
we checked earlier, car cranks normal, there is fuel but no spark.
Old May 3, 2006 | 11:50 PM
Turbo95Max's Avatar
ok wow....6speed conversion is DEFINETELY not worth doing......
Old May 4, 2006 | 06:47 AM
Larrio Motors's Avatar
Boss Chen Industries
I've could have told you that
It will all be worth it once its accomplished and you can drive it
Old May 4, 2006 | 09:14 AM
MaxBoost925's Avatar
Drug Money
Are you doing it for Hooper?
Old May 4, 2006 | 10:09 AM
Turbo95Max's Avatar
yea doing it for Hooper.......have WAAAAY too many hours invested in it already and it doesnt friggin start.
Old May 4, 2006 | 11:43 PM
Turbo95Max's Avatar
hummmm......nobody else have any info on this?
Old May 5, 2006 | 07:28 AM
Hoooper
maybe the computer doesnt recognize the transmission and therefore wont start because it doesnt think that there is one.
Old May 5, 2006 | 07:29 AM
Hoooper
if its still the auto ecu the immobilizer shouldnt be a problem. the only change is the transmission as far as the computer is concerned so that almost has to be it
Old May 5, 2006 | 10:56 AM
Turbo95Max's Avatar
what does your second sentence mean? the transmission shouldnt affect if the car starts or not. Unless there is something special about this 6speed i am missing.
Old May 5, 2006 | 05:23 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
I would closely compare the crank position sensor ring gear, on the AT flexplate and the 6spd flywheel. Its not immobilizer related..... I've been there and done that, and told the people its not cost effective.
When all else fails I got dibs on the tranny :P
Old May 5, 2006 | 07:03 PM
Turbo95Max's Avatar
do you kno if the 6speed crank sensor is different from the auto one?
Old May 5, 2006 | 09:40 PM
crank sensor reluctor wheel on the flywheel is diff on a 3.0L vs 3.5L. I have looked at 3.5L AT and 6spd flywheels and they looked different to my eye. I haven't swapped a 6spd in a 02 yet- nor I wanna so I dont know if there indeed is a diff. The reluctor wheel on the 3.5Ls does not detach from the flywheel like it does on a 3.0L. If it did it would make 6spd swaps into 3.0Ls much more eassier.
I want the 04 LSD tranny for my 3.0L because of its short gearing and better than 3.0L overdrive gears, for highway crusing. I sometimes find the gearing on my 3.0L too spread apart, with shorter gearing the car would be much faster I think.
EDIT- I wanna make myself clear that I mean that AT and 6spd flywheels looked diff to me just looking at the CKPS reluctor ring.
Old May 6, 2006 | 02:48 PM
Turbo95Max's Avatar
humm thats intersting. I think we'll drop the trans first and go from there.
You swapped a 6speed into a 4th gen? thanks for all your help.
Old May 6, 2006 | 05:42 PM
Hoooper
i put the manual ECU in that box of stuff, maybe if you hook that up it will start.
Old May 6, 2006 | 08:23 PM
Puppetmaster's Avatar
Its not that simple, you'll need a Consult-II and the NVIS/NATS software as well. The keys need to be registered with the ECU or NVIS/NATS won't allow the car to start.
Old May 6, 2006 | 08:25 PM
SoonerFan's Avatar
Cletus
true dat
isnt it past your bedtime?
Old May 6, 2006 | 08:45 PM
Originally Posted by soonerfan
true dat
Posting in my sleep...
Old May 6, 2006 | 10:44 PM
I've put 6spd trannies in 4th and 5th gens in the past. Not as eassy as a 5spd swap due to the tranny mount and flywheel modification- which was handled by Jeff at Maximum Tunning a while back. I can modify the flywheel on my own now as I finally have the avalible equipment to do so.
Old May 7, 2006 | 11:49 AM
Turbo95Max's Avatar
we're gonna drop the trans and compare the flywheel to the AT flex plate. hopefully it has something to do with that and we can finish this car. Got 3 other motor projects waiting.
Old May 7, 2006 | 01:14 PM
killical01's Avatar
i have a problem with my max staring sometimes. afther trying about 3 times all i do is take the key out and wait a few seconds and than trying again, and it starts.
Old May 7, 2006 | 01:15 PM
maxS
just have to have a parts car.
vsamoylov could chime in but he is banned but on his car he is using the ecu as well as the imobilizer and the key from a 2k2 max. all 3 of them have to match. for security reasons he has 2 ignition locks on his car and 2 keys. the ignition lock on the steering wheel starts the car with a regular key. the second lock has the immobilizer on it. if the second key with the chip isnt in the lock and you try to start the car, all it does is crank and crank. once you stick the second key into the lock and the immobilizer recognizes it, the car starts right up. another thing you have to know after a couple of times of cranking the car with a wrong key, the immobilizer will send a signal to the ecu telling the ecu that its the wrong key. nissan designed that for security reasons like if somebody tries to steal the car and uses a different key to try to start it.
also the fuel part of it is there. there is no spark and that is why the car doesnt start. a consult 2 will be needed as well to program everything together.
Old May 7, 2006 | 01:37 PM
mjk's Avatar
mjk
Head shot!!!
I recommend you call Jeff at maximum tuning. If you're running a flywheel from a 5.5th gen with a 4th gen ecu, then you will need to modify the flywheel, but that wont make it run right anyways, but it will start barely... Just call jeff... i would have saved a lot of money if i went straight there. To modify the flywheel, you'll need to go to a machine shop...
Old May 7, 2006 | 07:45 PM
Turbo95Max's Avatar
i sent him a message before he got banned and he never responded. I gave up on that one awhile ago.
We didnt change the ECU, kept the stock auto one in, so i dont believe its the immobilizer....could it still be? we're dropping the tranny tomrorow and comparing so we'll see from there...hopefully its that.
Old May 7, 2006 | 11:36 PM
A33 VQ30DEK's Avatar
wow. matthel! GO THE SHOP! haha
Old May 8, 2006 | 02:37 AM
mjk's Avatar
mjk
Head shot!!!
Call him up.
number found here:
http://maximumtuning.net/
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
ah2002
Mar 9, 2016 01:42 PM
fangorn
43
Jul 22, 2015 09:22 PM
Nick7455
Aug 30, 2006 02:38 PM
