Starter replacement
Old May 26, 2006 | 11:30 AM
1MaXXfan's Avatar
Starter replacement
Does anybody have the link to the thread on how to remove the starter? I found it awhile ago but no luck today.
Its just getting too consistent that it makes the overfire sound now, even though its warm.
I've also got to buy a replacement, any suggestions as to a good place to get it, my searches have found wild price ranges, rebuilt or new.
Thx!
Old May 26, 2006 | 12:25 PM
Love_00_Max's Avatar
IMO, I would go for a rebuilt starter (all starters work the same) and in many places they give you the rebuilt starter to replace and then you give back the old one.
Rebuilt starters are as good as new ones!!!
Old May 26, 2006 | 12:44 PM
FriscoMaxima's Avatar
Thx!
if i could do it 70 miles away from home, in complete darkness, only using my cellphone as a light source... ... i bet you'll figure it out once you pop your hood and take a look at it...
Old May 26, 2006 | 04:37 PM
MIXXMAX's Avatar
Just buy a remanufactured starter. Much cheaper and is just as good as new. Nissan's brand new ones are way overpriced. As far as replacement, just remove the air intake assembly and hoses going to the throttle. You'll then see the starter and have more room to work with. I changed the starter plenty of times on my '95 and they should basically be the same for the 5th gener's. You may have to remove some small stuff near the starter to pull it out, though. (I never had to change a starter on a 5th gener.....yet). Good luck!
Old May 26, 2006 | 05:45 PM
whazzzzuup's Avatar
Here is where the starter is located on transmission.
This is the starter off the transmission. There are 3 bolts that hold the starter to the transmission casing. There is one nut that connect the electrical wire and a plug.
If you look at the transmission on the left, you can see where the hole and threads for the starter is located.
Old May 26, 2006 | 06:27 PM
ZIPPIN's Avatar
Mauja He Mauja
check this>>>>>>>>>>>>>>>>>>>>
http://www.cardomain.com/ride/2076435
Old May 26, 2006 | 06:43 PM
AceofSpds's Avatar
wat
I changed my starter on tuesday... its really simple, nothing to it just un do the 2 bolts and un do the wires that hold it on. Took me 20 minutes tops.
Old May 26, 2006 | 08:33 PM
ZIPPIN's Avatar
Mauja He Mauja
Did you get an OEM starter?
Old May 26, 2006 | 08:44 PM
AceofSpds's Avatar
wat
Im pretty shure it was a re manufactured starter, i got it from advance auto.
Old May 27, 2006 | 12:19 PM
1MaXXfan's Avatar
Thx
You guys are the best. And here I was considering paying the stealership to handle this. Got to save money nowadays to pay for the gas so I'd rather do the things I can get my hands on that doesn't require special equipment.
Old May 27, 2006 | 12:28 PM
1MaXXfan's Avatar
how much?
Just something that I thought of, how much did you guys pay for new or remanufactured?
Old May 27, 2006 | 02:55 PM
igzy's Avatar
I Know Kwaliti
$50 used...
Old May 27, 2006 | 03:32 PM
AceofSpds's Avatar
wat
I think it was 130, a bit steep but they were the only place in town that even had one in their warehouse and i needed it that night.
Old May 30, 2006 | 11:08 AM
1MaXXfan's Avatar
uhmmm
Ok guys...any suggestions on where...everything I look up is like $150 and up. OEM is over $225 remanufactured from Courtesy. Waiting for some stealerships to get back to me.
Someone point me to a place they've used and trust.
Old May 30, 2006 | 11:50 AM
Max_Vader_2K's Avatar
What can cause your starter to go out anyway. Would the transmission have something to do with it?
Old May 30, 2006 | 12:23 PM
Gray305Max's Avatar
Opa-Locka Goon
I would like to know the same thing. Mine went out on me on Sat.
Old May 30, 2006 | 02:48 PM
MIXXMAX's Avatar
I doubt if the transmission has anything to cause a faulty starter. Eventhough the flywheel from the starter is connected to the transmission, most starters fail from bad solenoids or something ususally electrical.
Old May 30, 2006 | 07:36 PM
ZIPPIN's Avatar
Mauja He Mauja
Great.....................mine has been acting-up for a few months. Today was the worst ones. It almost did not start...
Old Jan 5, 2007 | 01:44 PM
eilison's Avatar
I replaced my old starter too and here is my experience of starter shopping.
I did some research in here before shopping. I set my mind on Bosch starter.
Autozone carries Duralast one for around $145;
NAPA carries Hitachi ones for $167;
Peppboy carries Prostar ones for $160;
I remember someone said that Peppboy carries Bosch, but my local peppboy store didn't have it. The staff explain that Prostar is the same as Bosch. Well, in fact, starters are almost the same. so I picked a Prostar.
my car is a 98 I30 and I found the original starter on my car is a Hitachi one. Nevertheless, the new Prostar one works pretty well.
just my 2 cents.
eilison
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
