Intake question...
Old Jun 5, 2006 | 07:14 PM
97Se5spd's Avatar
Intake question...
Please dont flame me for this but I want to get a Weapon-R intake from ebay. How much power do you get and is it worth it with the auto in my 03? Was it easy to install and how much did you pay? BTW, I cant search so...
Old Jun 5, 2006 | 07:16 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Can you read the FAQ's?
http://forums.maxima.org/showthread.php?t=36867
Old Jun 5, 2006 | 07:20 PM
irish44j's Avatar
retired moderator
in the two years you've been on here, you haven't read any intake threads??
Old Jun 6, 2006 | 06:27 AM
kramarz99
Did Anybody Had Problem With Leaking Anti-freeze After They Took Intake Manifold Of?
Old Jun 6, 2006 | 06:30 AM
SoonerFan's Avatar
Cletus
what does this have to do with the thread topic?
Old Jun 6, 2006 | 06:34 AM
kramarz99
Sorry For That....i`m Kind Of New In Posting New Threads, Don`t Know How To Do It...sorry For That Again...
I Got Some Problems With Leaking Anti-freeze, Just Hoped That Somebody Will New Enything About It...
Old Jun 6, 2006 | 06:45 AM
GBAUER's Avatar
A) please take off the caps because it makes your post look bad.
B) Stay on topic!
C) Take an English course
Now that I got the flaming out of the way, an intake should have nothing to do with an antifreeze leak. You don't have to take off the intake manifold to add an intake. If you're having a leak around the manifold, it's probably working it's way up from below because there shouldn't be any antifreeze in the IM. You need to look a little more around your engine for the leak. Try taking your car to a carwash and spray down / clean the engine bay first. Then drive it around for a bit and look for the leak. Should be easier to find then. If you still can't find it, there's stuff on the market that you can put in your antifreeze that glows under a black-light. This should make finding the leak easier. I'm guessing it's just a leaky hose and not a gasket as gasket leaks in the coolant system are not common on these cars.
Old Jun 6, 2006 | 06:48 AM
SoonerFan's Avatar
Cletus
does you new boss know you are on the org and not working
Old Jun 6, 2006 | 06:55 AM
GBAUER's Avatar
I'm "watching" the Cures videos now...
Really freaking exciting stuff!
Besides, I got a good "evaluation" last night!
(Cliffs: quit my jobby-job and now work for my wife. She owns 5 Curves locations)
Old Jun 6, 2006 | 07:06 AM
kramarz99
hey,
thanks for quick reply...you are right about that, those cars don`t leak around gaskets. My car looses antifreeze only when I drive it hard, if I go over 5000 rpm it hapens, but what the funny part is, is that you cannot see it. It seems like the antifreeze is comming from behind the EGR valve. Went to nissan dealer this morning and they said that there is no antifreeze going arount egr valve. I have changed hose comming of radiator and going into engine. Still same, would it maybe be pressure switch, because old manifold that i had was in really bad shape, so on the new one air flows better and it has more power, will that have anything to do with antifreeze leak?
Old Jun 6, 2006 | 07:11 AM
UGAd13's Avatar
GBAUER=
Old Jun 6, 2006 | 07:17 AM
kramarz99
antifreeze leak on maxima 2000
anyone had or have problem with antifreeze leak?
Old Jun 6, 2006 | 07:26 AM
GBAUER's Avatar
hey,
Check it when it's cold, run it hard, let it cool for a good 4 hours and check it again. I bet you're not losing anything.
Old Jun 6, 2006 | 07:28 AM
kramarz99
I`m loosing because just added some yesterday...
Old Jun 6, 2006 | 07:48 AM
MAXRB8's Avatar
hey,
Acutally there is a hose carrying anitfreeze that is connected to the IM at the back of the IM on the driverside.
Back to the original thread, you get significant gains in the upper rev range, but loose a little bottem end power, IMO the trade off is worth it. I've swtiched a few times between stock and my Injen and definitely prefer the Inken setup, but then again I do have it coupled with a Catback which in combo works very well.
Old Jun 6, 2006 | 08:26 AM
kramarz99
I Got The Same Exhaust System And Intake. Do You Know Where I Can Find Some Type Of Schematics That Would Show Me How Antifreeze Flows In 2000 Maxima?
Old Jun 6, 2006 | 01:23 PM
merovi's Avatar
you should go with the berk or frankencar, best bet is with the apexi filter, but the K&N is alright. pick them up used or new ont he org and they arne't too expensive. I think there is a berk for sale in the FS section, it might be taken though. The GAB is good, but after just switching from the GAB to frankencar, it sounds so much better.
Old Jun 6, 2006 | 05:41 PM
irish44j's Avatar
retired moderator
1. This thread was lame in the first place
2. This thread got 10x as lame when it was hijacked
3. This thread will certainly get even lamer if someone doesn't lock it
Old Jun 6, 2006 | 05:54 PM
NmexMAX's Avatar
dot dot dot ...
Yes there is.. Near the TB.
Old Jun 6, 2006 | 06:43 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Yet another successful intake thread
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
