BRAKE Light
Old Jun 13, 2006 | 06:26 AM
Pri63's Avatar
BRAKE Light
My brake light comes on intermittently but recently it has just stayed on. What causes a brake light to come on?
Old Jun 13, 2006 | 06:28 AM
SoonerFan's Avatar
Cletus
the sensor on the pedal is stuck
Old Jun 13, 2006 | 06:31 AM
FoggyboTTom's Avatar
explain please cause i got the same problem
Old Jun 13, 2006 | 06:49 AM
MIXXMAX's Avatar
Check your brake fluid. It may be low. Low brake fluid sometimes trips the brake light to come on.
Old Jun 13, 2006 | 06:53 AM
meccanoble's Avatar
Sports Button FTW
this has happened to me when my battery showed signs of close to failure...but after some driving it goes away along with dim lights and other signs....but i see a lot of people say its sensor....do u smell the brakes after driving? as if u were riding on them?
Old Jun 13, 2006 | 07:15 AM
Pri63's Avatar
No smell of brakes are driving so they're definitely not dragging.
the brake fuild is at the right level.
I'm guessing I should check the sensor that soonerfan mentioned. Sooner want to elaborate on what you were talking about?
Old Jun 13, 2006 | 07:21 AM
SoonerFan's Avatar
Cletus
look under the dash at the top of the brake pedal...there should be a sensor on the arm
Old Jun 13, 2006 | 09:38 AM
9DTALON's Avatar
I think these guys are talking about the light on the dashboard, not the actual lights on the back of the car. I'm not sure if its the light that comes on with the E-brake or the ABS light that you guys are talking about though.
Old Jun 13, 2006 | 09:41 AM
MaxBoost925's Avatar
Drug Money
no, they're talking about the actual tailights.
Old Jun 13, 2006 | 10:43 AM
ikalinin's Avatar
No i'm pretty sure they're talking about the "brake" light on the dash when ebrake is pulled.
I had the same problem. There is a little spring pin with a contact on the end, and when you pull the ebrake, the pin springs in and touches a contact to illuminate the "brake" light. In my case, a candy/ gum wrapper fell in and it somehow got stuck in the pin, so it brought it closer to the contact, so my brake like kept going on and off and sometimes just illuminated very dimmly (is that a word? haha) Remove the center counsel (5 bolts, literally) and check it out. its a 15 minute fix. (in my case)
Here is the how to I requested.
http://forums.maxima.org/showthread.php?t=475803
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
