Wheel bearings
Wheel bearings
Can you someone help me how do you check to see if your wheel bearings are bad sunday i changed my back rotors now at 65 my car is shaking
mind you i had no problems before i did this also does wheel bearing go bad
that fast i did check the wheels there tight left right up and down does the wheel always have play in it when they go bad or make noise
The wheel does not always have play in it. The only definitive way to check a bearing issue is to remove all the components on top of it (rims, axle nuts) thus exposing the bearing and turning it to see how smoothly it operated. The rears are easy. Take the rim off, remove the axle nut and rotor, and turn the bearing. IF it is dead smooth without and roughness and the wheel does not have any play then the bearing is probably not causing the problem.
Originally Posted by Lovemycar
Thanks guys i'm going to have all four bearings checked tomorrow and
have my back brake rebone with new rotors
londonflu
40
Sep 25, 2015 09:11 AM
