"service engine soon"
Old Jun 29, 2006 | 10:16 AM
maxmumsxspd's Avatar
So i was driving myself home from my friends house on sunday and sudenly my "service engine soon" light came on (i was driving calmly, no showing off lol).
So i called up my dealer and had them check it out...this is what they found:
i need a new vent control valve: $230, new intake timing solonoids: covered under warranty.
I am going to have my mechanic do this for me i think (he also has a maxima but a 00 AE 5spd).
Also there is a cracking sound for a split second when i start my car...doesnt sound good...and nissan couldnt diagnose the problem. its only on a cold start. i think maybe thats the VDC, but not sure.
Also i stated before i think in another thread that i had a problem w/my tach that it wobbles its way up, and they said i need a new tach. with installation nissan wants to charge $345 and just the tach they want $207...should i do it? or just leave it alone for now, or install the thing myself?
thanks a lot in advance
ps. i have an 02 6speed w/o HLSD
Old Jun 29, 2006 | 11:22 AM
aanyyyonnneee?
Old Jun 29, 2006 | 12:26 PM
GBAUER's Avatar
vent control valve: probably the EVAP purge valve. $80 part and takes about 10 minutes to change. Don't let Nissan screw you. The start-up sound: does it sound like a rattle? If so, it's normal. It is the timing chain rattling before the tensioner get's enough oil pressure to tighten it. You may want to check your oil level also. If it's low, have tell the dealership and they will have to do a consumption test. If your car is consuming more than a quart every 1,000 miles, they are obligated to give you a new engine. A lot of 3.5's have this problem. I'll do a search on the EVAP issue.
boondoxmax's Avatar
Leave it alone. When my 02 had the dim SEL, nissan replaced the gauge cluster and the new one had a funny acting tech. It would wobble un and down also. I just lived with it cause I didnt feel like dealing with Nissan.
Old Jun 29, 2006 | 12:27 PM
GBAUER's Avatar
Here you go: http://forums.maxima.org/showthread....ap+purge+valve
Old Jun 29, 2006 | 01:00 PM
thanks a lot for the help guys...
the dealer is ordering the parts for the solonoid replacement, but other than that i will do the purge valve myself and see if it solves the problem
i appreciate all the help
Old Jun 29, 2006 | 07:49 PM
shysmax's Avatar
Why would u do the purge valve yourself, if u stated earlier, it is covered by warranty?
Old Jun 29, 2006 | 10:37 PM
I have an extended warranty that i bought w/the car (got it used w/58xxxmi) that won't cover it supposedly (the dealer "talked" to them, but ill verify that haha)...
Old Jun 29, 2006 | 11:22 PM
gxe2se's Avatar
extended warranty should cover everything. usless its considered wear and tear...
I don't think it is. It should be covered. I had everything covered with my extended warranty.
Good Luck
-Antony
Old Jun 29, 2006 | 11:44 PM
MaxBoost925's Avatar
Drug Money
fyi. 2000 was not AE.
the 2001 was AE.
Old Jun 30, 2006 | 09:16 AM
the 2001 was AE.
thats what i meant, my bad
Old Jun 30, 2006 | 09:19 AM
Good Luck
-Antony
I'm gonna call up the insurance company myself today and make sure of what the dealer claimed. thanks a lot bro
shilov
Feb 19, 2024 09:40 PM
Pixel
Sep 15, 2015 05:53 AM
seesole
Sep 14, 2015 12:38 PM
Steven Orozco
Sep 12, 2015 10:41 PM
jfl330
Sep 4, 2015 01:44 PM
