steering wheel not straight...common issue?
Old 07-16-2006, 11:54 AM
2002 maxima se
OC guy's Avatar
for some reason my cars steering wheel doesnt stay straight while i am driving i can see its shifted toward left just about 1 or 2 inch, when i try to bring it straight it pulls toward right which mean in order to stay on straight track i have to keep the steering a bit on left...is this a common issue or it has something to do with suspension or alighnment? how to fix this probelm?
OC guy is offline
Old 07-16-2006, 12:04 PM
MONTE 01&97 SE's Avatar
Alinement issue, or you could have radial pull or you could have uneven tire wear. Does it do it on all roads because the crown of the some roads can cause that, it is so many different variables when it comes to this situation.
MONTE 01&97 SE is offline
Old 07-16-2006, 12:07 PM
2002 maxima se
OC guy's Avatar
it stays crooked all the time no matter where i drive.
i just got 4 new kumho's asx a week ago but this problem has been there since i bought the car. could be alignment?
OC guy is offline
Old 07-16-2006, 12:22 PM
It's business time.
Progress's Avatar
I had this issue pretty badly. When you get an alignment tell them about it and they'll make sure to align it with the wheel straight.
Progress is offline
Old 07-16-2006, 12:36 PM
Jung Yun's Avatar
definetely alignment
Jung Yun is offline
Old 07-16-2006, 01:27 PM
bigEL's Avatar
The tech who did the last alignment (probably before you bought your car) didn't correct the tie rods after the alignment. You can do it yourself if you want. Just make sure you turn both tie rods by the same amount in the same direction to maintain proper alignment. Or you could get an alignment just to be sure and tell the tech to fix the problem while he's at it. Or just leave it alone, as long as your car drives straight. Unless your car pulls or darts on flat roads when your hands are off the steering wheel, it's ultimately just an aesthetic issue.
bigEL is offline
Old 07-27-2006, 12:41 PM
Mints33's Avatar
Steering wheel not being straight can be quite annoying!
Mints33 is offline
Old 07-28-2006, 09:10 AM
Edward Lee's Avatar
Adjust your tie rods. It relatively easy. If you need help, pm me and I'll give you a hand. I live in San Gabriel which is not too far from you.
Edward Lee is offline
Old 07-28-2006, 12:06 PM
Puerto Rico-Maxima Lover
Lontar1's Avatar
alignment issue...
Lontar1 is offline
trasmadean
02-01-2017 08:20 PM
Maxima_Joe
11-25-2015 08:19 AM
spidgeon
08-31-2015 08:37 AM
tnewbs
08-28-2015 10:15 AM
jhontelj
08-17-2015 04:07 AM
Quick Reply: steering wheel not straight...common issue?
