5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Mar 5, 2008 | 09:21 AM
  #5241
Prophecy99's Avatar
anything goes in here...so heres some of my curious noobage questions...
Exhaust.....maybe someone could point me in the right thread...etc...
I would love to replace some portions of the exhaust. What are the best bang for buck pieces to change?? (FYI I still want to be quite )
Thanks for any info.
Old Mar 5, 2008 | 10:40 AM
  #5242
Scottwax's Avatar
That's Mr. Detail to you
Headers, y-pipe and B-pipe. Stock muffler should support 300 hp or so without being a major restriction. Keeping it quiet means no cops bothering you, no ricers reving on you and no drone at freeway speeds. The header and exhaust clips stickies should have everything you are looking for.
Old Mar 5, 2008 | 12:17 PM
  #5243
chandmx's Avatar
If I put on lowering springs all around without replacing the struts, would my old struts ruin the springs by not giving enough support?
Old Mar 5, 2008 | 12:18 PM
  #5244
SunDown13X's Avatar
Originally Posted by soonerfan
he is going to do it so its actually -
"i need an oil change"
wait
wait
wait
pay
drive away
hahahaha dude you made me blow my chocolate milk with that one! LOL $hit!
Old Mar 5, 2008 | 12:19 PM
  #5245
spdfreak's Avatar
What struts/shocks are currently on the car?
Old Mar 5, 2008 | 12:50 PM
  #5246
chandmx's Avatar
stock
Old Mar 5, 2008 | 12:53 PM
  #5247
spdfreak's Avatar
stock
Have they ever been replaced, or are they as old as the car?
Old Mar 5, 2008 | 12:55 PM
  #5248
spdfreak's Avatar
stock
IIRC, stock shocks with lowering springs won't last long because they are out of their operating movement (for the lack of a better explanation).
You may as well change the shocks when you change the springs. Why work twice?
Old Mar 5, 2008 | 12:58 PM
  #5249
SoonerFan's Avatar
Cletus
the struts would go bad
Old Mar 5, 2008 | 01:55 PM
  #5250
Prophecy99's Avatar
thanks scott.. much appreciated..... beginning myon the pieces you mentioned...
Old Mar 5, 2008 | 07:49 PM
  #5251
User 12822's Avatar
What would cause a slight whine in the engine in 1st and 2nd gear when accelerating slowely in between 1,700 and 3,000 rpms?
Old Mar 5, 2008 | 09:58 PM
  #5252
Scottwax's Avatar
6 speed or auto?
Could be electrical interference, had a real problem with a Celica until I realized the whine was in the stereo and caused by the Jacobs ignition box.
Old Mar 5, 2008 | 10:17 PM
  #5253
danger300z's Avatar
any of you guys are using or have used d2s bulbs? are the brighter than d2r bulbs?
Old Mar 5, 2008 | 10:24 PM
  #5254
Maxxedout01's Avatar
i just bought an HID kit and i followed the directions and plugged everything into the correct place and then when i when to plug the harness into the stock harness ans i turned my headlights on nothing happened but the high beams work. the low beams are supposed to be hid and the high beams are supposed to be the halogen. any suggestions
Old Mar 6, 2008 | 04:33 AM
  #5255
User 12822's Avatar
Originally Posted by Scottwax
6 speed or auto?
auto and is definitely coming from the engine, not the radio/stereo.
Old Mar 6, 2008 | 07:31 AM
  #5256
NmexMAX's Avatar
dot dot dot ...
Mine does the same thing, never really questioned it.
Old Mar 6, 2008 | 08:47 AM
  #5257
DrunkieTheBear's Avatar
Turbo'd Saab
either you need to flip the connector on the HID ballast, or you need to flip the two grounds around on the HID connector to the stock harness
Old Mar 6, 2008 | 01:07 PM
  #5258
EvoEnvy's Avatar
Can someone please give me a direct link on how to install 2 12" subwoofers and amp using the stock Bose system deck. I know I need a hi-low kit but I need a diagram of where to make the connections...HELP!
Old Mar 6, 2008 | 03:00 PM
  #5259
Scottwax's Avatar
They don't work well unless in projector housing.
Old Mar 6, 2008 | 03:04 PM
  #5260
SoonerFan's Avatar
Cletus
im pretty sure thats avaliable in the audio subforum
Old Mar 7, 2008 | 06:38 AM
  #5261
willsmax00's Avatar
Could anyone tell me what this rubber hose is supposed to be or what does it connect to??
I found it this way.
Thanks!
Old Mar 7, 2008 | 06:54 AM
  #5262
BCoon's Avatar
Google a PAC AOEM-NIS2
Old Mar 7, 2008 | 08:44 AM
  #5263
SoonerFan's Avatar
Cletus
willsmax00,
transmission breather hose....its normal...leave it alone
Old Mar 7, 2008 | 10:00 AM
  #5264
BCoon's Avatar
I tried pulling up a few different posts in the how to thread.. replacing "show" with "old" isn't working for me anymore... (I was looking for 2002 spark plug replacement)
Old Mar 7, 2008 | 10:02 AM
  #5265
SoonerFan's Avatar
Cletus
http://www.greghome.com/Greg%27s%20G...eplacement.htm
Old Mar 7, 2008 | 11:36 AM
  #5266
NmexMAX's Avatar
dot dot dot ...
It will only work if it is linking an entire thread, not a specific post.
Old Mar 7, 2008 | 11:39 AM
  #5267
BCoon's Avatar
Yea, I tired knocking the part of the URL that deals with showing the post.. and changed show to old, and it still didn't work.
The link Sooner gave me is perfect.
Thanks guys!
Old Mar 7, 2008 | 06:41 PM
  #5268
willsmax00's Avatar
willsmax00,
Thanks sooner, appreciate it.
Old Mar 8, 2008 | 12:52 PM
  #5269
SuperStasiu's Avatar
Alot
ps pump
ac compressor
alternator<- i'd put my money on this since its under load
loose intake piping
wheel bearings
axles
a loose or cracked vacum line
loose weather stripping
Old Mar 8, 2008 | 01:52 PM
  #5270
User 12822's Avatar
Okay now I have a fairly concerning problem. When I start the car after it has been sitting over night or after the engine has had time to cool smoke comes out of the exhaust just for the start up. What could be causing this?
Old Mar 8, 2008 | 01:53 PM
  #5271
SoonerFan's Avatar
Cletus
what color is the smoke?
Old Mar 8, 2008 | 01:57 PM
  #5272
User 12822's Avatar
Grayish Black, like something is burning.
Old Mar 8, 2008 | 10:33 PM
  #5273
01GLEMist's Avatar
When I start the car in the morning (usually on cold mornings) for the first few times I brake, the brakes make a horrible loud sound. (Not really metal on metal though). After braking about 2-3 times, it seems normal. What could cause this?
Old Mar 9, 2008 | 09:14 AM
  #5274
BCoon's Avatar
Are they more sensitive as well? Its like they almost lock up, but after they go around a few times, whatever on the rotors/pads is gone and they work normally. I notice it most after rain..
Mine did this is my Wrangler and Xterra as well.. not yet in my Maxima..
Old Mar 9, 2008 | 10:57 AM
  #5275
spdfreak's Avatar
What pads and rotors are on the car, and when were they changed last?
Old Mar 9, 2008 | 12:46 PM
  #5276
00MaximaGLEgrl's Avatar
I've searched and I have found too many different things. Does anyone have any suggestions as to why my car stalls when its in park? It only stalls after i've been driving. Once i stop and put it in park it idles normal for about 20 seconds then the rpms drop and it stalls. It doesnt do it in the morning when i start it to warm it up and it always starts right back up after it stalls. Its fine when im stopped at a light or something. It only happens in park after driving. The coils have been replaced and so has the oxygen sensors and catalytic converter. Those things were all replaced due to the SES being on. The SES is not on anymore. Its going back to the shop this week but i know they will tell me nothing is wrong seeing as though there is no SES on. Does anyone have an advice on this for me? id like to be prepared when i bring it in. Its been doing this since i bought it and each time ive brought it in to have something fixed they always say "it could be happening because you need coils/oxygen sensors/ catalytic converter." And now all of those things have been replaced and its still doing it...if anyone has AIM you can IM me (screen name: CbGtGrl) if its easier to talk that way...Thanks in advance!
Old Mar 9, 2008 | 12:47 PM
  #5277
NmexMAX's Avatar
dot dot dot ...
ECTS? MAF? Dirty IACV?
Old Mar 9, 2008 | 01:36 PM
  #5278
SunDown13X's Avatar
just wanted to comment of the gas question from before...
yes... car feels and run smoother with higher grade fuel.
Old Mar 9, 2008 | 01:40 PM
  #5279
BCoon's Avatar
I'm about to buy a Progress RSB and I'm looking for a FSTB compliment. Otto seems to be a good decision, but I can't find anywhere that sells them. The Southwest Autoworks website seems to be down, or non-existant...
  #5280
SoonerFan's Avatar
Cletus
which is why nissan says to use it....
