5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Mar 2, 2008 | 11:30 AM
  #5201
SunDown13X's Avatar
Originally Posted by nebojsa_o
Well, the first thing people here would ask is what kind of gas do you use? Octane level?
I was going to ask, is 87 oct on an atx 2000 GLE ok? Doesnt say to put premium only and I dont have the manual...
D.
Old Mar 2, 2008 | 11:42 AM
  #5202
SunDown13X's Avatar
D.
never mind... found the book and it says 87 oct is ok (good saves me a few bucks )
Old Mar 2, 2008 | 11:57 AM
  #5203
SoonerFan's Avatar
Cletus
it may say that its ok, but it also says that premium is recommended.
please use premium...you dont save that much by using cheaper gas.
Old Mar 2, 2008 | 12:52 PM
  #5204
colo's Avatar
I suck at electrical stuff... but I hope these can help...
Thanks. I'm going to check it out right now.......
Old Mar 2, 2008 | 12:55 PM
  #5205
SoonerFan's Avatar
Cletus
did you need to include those huge images in the quote
Old Mar 2, 2008 | 01:31 PM
  #5206
SunDown13X's Avatar
It says to use 91 aki fuel which is 87 oct. but you are right it does say premium is recommended...
Old Mar 2, 2008 | 01:41 PM
  #5207
colo's Avatar
Do you know where the flasher unit is located? Thanks........
Old Mar 2, 2008 | 01:45 PM
  #5208
JavY's Avatar
yeah that sounds like it will fix the problem.. do to money issues i was putting the cheapest gas around. guess i gotta do whats best for the maxima !!
Old Mar 2, 2008 | 04:11 PM
  #5209
irish44j's Avatar
retired moderator
Originally Posted by mrivera78
i have a 2000 gle..i know that you can aim headlights up and down but can they be aimed left to right?
thanks,
mat rivera
IIRC there is a small amount of adjustment in the upper mount screws. You could also enlarge the holes a bit if you need more adjustment. If your headlights are out of alignment left/right, you might have another problem though.
Old Mar 2, 2008 | 04:14 PM
  #5210
irish44j's Avatar
retired moderator
Originally Posted by impalasscars
Well, problem 1/2 solved. The car now runs better, but will not stay idled for over a minute after warmed up or after driving. Idles good first thing in the morning or when cold. Replaced the MAF due to idle issue and sputtering, and it made the car run better, but still having the idle issue. Got a SES code of P0140, which made me replace the rear o2 sensor after the CAT today. Reset the SES, but still have the idle issue. Could this be a bad idle air control? If so, how do I go about replacing it?
first do the idle air reset procedure....
could also be a coil, spark plugs, MAF, etc.....not bad enough to throw a code but still may not be fully "ok"
  #5211
irish44j's Avatar
retired moderator
Originally Posted by dominicano3o5
if my Throttle Position Sensor Went bad What can happen???
hesitation and engine bogging, usually.
Old Mar 3, 2008 | 07:49 AM
  #5212
ghostridden's Avatar
ok i've gotten my skip fixed when its REALLY cold outside, i think anyways, HOWEVER its also been just dying RIGHT when i crank it unless i tap the gas peddle right when i crank it, also its just started this, when i try to crank it, it acts like its outta gas, not all the time, but sometimes, sounds like fuel filter maybe? the MAF is only a year old so that shouldn't be a problem, new coils and plugs, PCV valve is new also, so sounds like fuel filter or pump maybe?? any suggestions?
Old Mar 3, 2008 | 08:36 AM
  #5213
jbrooks870's Avatar
does anyone know how to repost existing threads? i dont want to have to create new ones. thanks.
Old Mar 3, 2008 | 09:41 AM
  #5214
SoonerFan's Avatar
Cletus
post in it to bring it to the top
Old Mar 3, 2008 | 01:57 PM
  #5215
macnolias's Avatar
I currently have an 02 gle and I'm looking to get another maxima/g35 steering wheel.
My question is what cars and models can I replace my steering wheel with to still have steering wheel controls.
Old Mar 3, 2008 | 03:02 PM
  #5216
irish44j's Avatar
retired moderator
none that I know of
Old Mar 3, 2008 | 04:41 PM
  #5217
rroderiques77's Avatar
Demodded and Forgotten
D.
It may say 91 octane only near the gas door.
Some also argue that you will save money by using 91 octane gas because the it doesn't burn as fast as 87 octane.
My tanks actually last longer now that I use higher quality gas.
Old Mar 3, 2008 | 06:16 PM
  #5218
SunDown13X's Avatar
Im going to have to wait until im empty and fill it up with 93 to see...
Old Mar 3, 2008 | 07:24 PM
  #5219
maxximaa's Avatar
HELP!!
Please confirm!!!
Any short ram-style intake other than the JWT POP intake, it is causing unacceptable levels of turbulance across the hotwire in your MAF. The simple but sophisticated velocity stack in the JWT intake does its job and very little turbulance reaches the MAF hotwire - no other short ram intake does this.
So weapon R, Berk, Franken Car are no good then?
What would the results be if the turbulance reaches the MAF hotwire??
Old Mar 3, 2008 | 07:30 PM
  #5220
NmexMAX's Avatar
dot dot dot ...
I wouldn't say they're no good, but IMO, the POP is best, other than doing something a little more involved.
Old Mar 3, 2008 | 07:32 PM
  #5221
SoonerFan's Avatar
Cletus
the apexi filter has the velocity stack and it can be used on any short ram intake...like on my berk.
Old Mar 3, 2008 | 07:43 PM
  #5222
maxximaa's Avatar
Im not sure what you mean
Old Mar 3, 2008 | 07:44 PM
  #5223
maxximaa's Avatar
I have Weapon R (not on the car yet) and buying Apexi filter, would there be any problem with the MAF which would cause the engine light to come on?
Old Mar 3, 2008 | 07:48 PM
  #5224
NmexMAX's Avatar
dot dot dot ...
Spend some time in here for more info.:
http://forums.maxima.org/forumdispla...aysprune=&f=61
Old Mar 3, 2008 | 07:49 PM
  #5225
NmexMAX's Avatar
dot dot dot ...
You’re worrying too much, just put on what you have.
Old Mar 3, 2008 | 08:11 PM
  #5226
irish44j's Avatar
retired moderator
I wouldn't say they're no good, but IMO, the POP is best currently available, other than doing something a little more involved.
fixed for you...
Old Mar 3, 2008 | 09:01 PM
  #5227
NmexMAX's Avatar
dot dot dot ...
They're all currently available, it just matters how hard you look, or how creative you are. And I still don't think PRCAI is the best ever, so that opinion is subjective.
Old Mar 4, 2008 | 08:14 AM
  #5228
Jaz2001's Avatar
hey everyone,
Not trying to intentionally highjack, but what are your thoughts on this book? Is it something that any of you have used or would recommend?
http://www.car-stuff.com/carparts/ni...h16720211.html
Thanks in advance
Old Mar 4, 2008 | 09:29 AM
  #5229
NmexMAX's Avatar
dot dot dot ...
Originally Posted by Jaz2001
hey everyone,
Thanks in advance
I have 1, paid less than that for it. It has been noted that it is missing some viable information, and in some cases has misinformation. It's a good book for some items.
These are free and far more informative:
www.vq35de.com/ESM
Old Mar 4, 2008 | 12:53 PM
  #5230
Jaz2001's Avatar
Thanks very much.
I will look into this book and the link that you recommended.
Old Mar 4, 2008 | 02:51 PM
  #5231
spdfreak's Avatar
www.vq35de.com/ESM
The FSM can also be downloaded at phatg20.net
Old Mar 4, 2008 | 03:30 PM
  #5232
NmexMAX's Avatar
dot dot dot ...
And here:
http://www.aubreyandcharles.com/NissanServiceManuals/
Old Mar 4, 2008 | 05:44 PM
  #5233
BigMarcus's Avatar
I want to get the opinion of some .org people....I am looking at a 2002 SE 6spd with every option except HLSD and navi. It has 87,000 miles and mild curbrash on two tires. The dealer is asking 13.5 for the car and I know that is way to high but I was wondering how 12/11.8 sounded for it.The car is clean for the most part .....thoughts?
Old Mar 4, 2008 | 05:47 PM
  #5234
NmexMAX's Avatar
dot dot dot ...
www.nada.com
www.kbb.com
Plug the options in and your Zip, and see what you come out with. You have a better idea of its condition since you've seen it, so if you equip yourself with the information on those sties above, you should be able to answer your own question.
Old Mar 5, 2008 | 06:19 AM
  #5235
JavY's Avatar
on the way to do an oil change.. any recommendations ???
Old Mar 5, 2008 | 06:24 AM
  #5236
NmexMAX's Avatar
dot dot dot ...
Remove nut, drain, repalce filter, refill.
Old Mar 5, 2008 | 06:29 AM
  #5237
JavY's Avatar
thanks.. but what type of oil ?? synthetic ??
Old Mar 5, 2008 | 06:30 AM
  #5238
SoonerFan's Avatar
Cletus
he is going to do it so its actually -
"i need an oil change"
wait
wait
wait
pay
drive away
  #5239
NmexMAX's Avatar
dot dot dot ...
I use synthetic, use whatever you want.
Old Mar 5, 2008 | 06:44 AM
  #5240
JavY's Avatar
my fault yess i'am doing a pay and drive.. thanks for your help NmezMAX i will use synthetic !!
