5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old May 19, 2010 | 11:07 AM
  #10681
Nelsito65's Avatar
Originally Posted by nespino
2001 maxima transmission slippage when I run around town. RPMs go down, push throttle, revs up but car does not move. Check engine light came on, indicated transmission. Dealer says they check it and nothing wrong. Does anyone have any ideas on what it could be? change tranny oil, filters, etc? Any guidance would be appreciated.
If you know the actual code that was pulled when the engine light came on, do share it with us. (It's usually the letter "P" followed by four digits). If you don't, then you might want to get that piece of information. Some auto part stores, and some service shops, offer that service for free.
Old May 19, 2010 | 05:36 PM
  #10682
gwshearer's Avatar
just bought a 2002 maxima SE
I can tell the battery in the standard viper remote is going bad. When I went to take it apart I noticed that the circuit board doesn't come off easily (or at all) to access the battery. So what's the process to replace the battery?
(And yes I did search, to no avail)
Thanks!
Old May 19, 2010 | 08:19 PM
  #10683
drumham's Avatar
does anybody know where I can get eyelids for my 00 maxima? I don't want the ones that look like they do no difference... I want to ones that are low. i'm talking.. low
-_-
Old May 20, 2010 | 07:39 AM
  #10684
homeyclaus's Avatar
Originally Posted by mdrache
SNIP!
P0115 Coolant Temperature Sensor
p0138 Heated Oxygen Sensor Bank 1 Sensor 2 (Circuit high voltage)
p0139 Heated Oxygen Sensor Bank 1 Sensor 2 (Circuit slow response)
p0140 Heated Oxygen Sensor Bank 1 Sensor 2 (Circuit condition)
p0158 Heated Oxygen Sensor Bank 2 Sensor 2 (Circuit high voltage)
I bought another CTS and will change it tonight, but I'm wondering whether the thermal transmitter should be changed as well.
Also, I've read different opinions on whether the ECM should be flashed after MAF is changed or whether it's enough to disconnect the battery for half an hour.
Any opinions are truly appreciated.
You're doing the right thing. You should not have to reflash the ECU, even if there is such a procedure. You shouldn't even have to do a idle relearn, although some do, and if you're still having idle problems, it would not make that worse.
If the temp sensor code clears, and the O2 sensor codes persist, that combination of codes leads to the conclusion that there is a circuit problem. I'd make sure the cables aren't pinched and that the connection is sound before replacing those.
Old May 20, 2010 | 12:10 PM
  #10685
maximer's Avatar
ok so im obviously new here, a noob i guess u would call it. ive got an 03 se/te 6spd pearl white maxima. ive recently purchased a berk intake w/apexi filter, nwp vias delete/block plate, and in the mail as we speak is the nwp intake manifold spacers. just trying to get all the intake stuff out of the way first. starting at the front of the car and making my way backwards soon with headers, test pipe and catback. the intake stuff is off the car so bone stock is how it sits. ooooo almost forgot, d2 coilovers get in in about 10 days ))))). question, im planning on running a 75shot later on down the line, clutch kit recommendations please! any input is appreciated
Old May 20, 2010 | 09:16 PM
  #10686
drumham's Avatar
I need help taking my headlight housing out of my 00 maxima.. help please
Old May 21, 2010 | 12:25 AM
  #10687
ArchStone's Avatar
This is the thread I was looking for!
I'm new to this forum, but not new to the internet.. or forums in general, so don't judge so much by the post count.
Just recently purchased a 2000 Maxima SE automatic with 128k on the odometer. I've started fresh by flushing the transmission/coolant/brake/ and power steering. Check engine light has already come on (within a week). Says it's a slow responding O2 sensor in 2nd bank.. I'm gonna let it go for now, I doubt it's a major problem. Anyways...
I'm looking to wake it up a bit by adding a chip, exhaust system, and intake. I'd want the exhaust note to be more on the subtle side. Suggestions for all of the above would be AWESOME!! ...it'll save me a TON of time searching through endless pages or forum.
Is a chip from Performance Chip Direct worth anything?
Thanks again for you time!
I'll probably end up hanging around here as long as I have my Maxima
Old May 21, 2010 | 01:12 AM
  #10688
SoonerFan's Avatar
Cletus
welcome...a "chip" is pointless on our cars
Old May 21, 2010 | 06:15 AM
  #10689
NmexMAX's Avatar
dot dot dot ...
Unless it's a reprogram by TS.
http://www.technosquareinc.com/maxima.htm
Old May 21, 2010 | 08:40 AM
  #10690
homeyclaus's Avatar
Welcome aboard.
In both the exhaust section as well as some threads on the 5 gen forum, members post both pictures and sound clips of their Maximas with their exhaust system specs. That should give you a starting point.
As others noted, a chip isn't worth it on a Max. It gets you a whole lot of headache with less performance gains than intake and exhaust mods for most applications.
Old May 21, 2010 | 08:51 AM
  #10691
NmexMAX's Avatar
dot dot dot ...
Headache? Explain?
A chip these days could be a # of things. A TS ECU is a good mod.
Old May 21, 2010 | 09:27 AM
  #10692
matek07x's Avatar
im working on my 15 posts ,not a big fan of that rule whats so ever.
Old May 21, 2010 | 09:36 AM
  #10693
NmexMAX's Avatar
dot dot dot ...
That was useful ...
I bet we wont be a fan when you post something that's been answered 10e^10 times
Old May 21, 2010 | 03:24 PM
  #10694
gwshearer's Avatar
Thanks!
Any ideas?
Old May 21, 2010 | 11:10 PM
  #10695
NmexMAX's Avatar
dot dot dot ...
The battery on the Viper remote?
On a Maxima forum?
Maybe Viper remote
Old May 21, 2010 | 11:31 PM
  #10696
gwshearer's Avatar
On a Maxima forum?
Maybe Viper remote
Hey, thanks for being useless!
Since it comes with Maximas, it seems stupidly relevant...
Old May 22, 2010 | 12:32 AM
  #10697
NmexMAX's Avatar
dot dot dot ...
Does Viper commonly come with Maximas?
This is a Maxima board, not a Viper Board, had you asked about a Maxima FOB, I could have and would have answered it to my capacity ... but, Viper? Perhaps your particular model # and take it from there..
Old May 22, 2010 | 07:03 AM
  #10698
m.xie's Avatar
I have a 2000 Maxima GLE with 160k miles. Recently, I found that when I wanted to accelerate from speed around 20 mph, when I press the pedal slowly, the transmission swift not smoothly. The rotation speed of the motor would go to about 3000 rpm. It felt like the car was dragged. After that everything was OK.
Is it the problem of the transmission? Will it be serious and how can I know it?
Thank you so much.
Old May 22, 2010 | 07:25 AM
  #10699
Nelsito65's Avatar
Thank you so much.
Does it happen to be going down on roads with a slight incline? Mine does that ocassionally. For some reason it used to happen more often before I changed my passenger side motor mount. I guess the new mount tightened things a bit, not allowing too much play around the transmission housing.
You might want to check the conditon of you transmission fluid and/or change it if you haven't done so in a while.
Old May 22, 2010 | 07:42 AM
  #10700
m.xie's Avatar
Thank you so much for your quick response.
I think there is nothing to do with the road. I will check the condition of the transmission fluid once more, because several days before, I just got it inspected in a Nissan dealer, they told me all the fluids are OK.
But, they DID tell me that I should change my upper sturt amounts. Are these what you have changed? Is there anything to do with the transmission?
Thank you again.
Old May 22, 2010 | 08:05 AM
  #10701
m.xie's Avatar
Does tune-up have anything to do with this problem?
How do I know whether I need a tune-up or not?
Thank you.
Thank you so much.
Old May 22, 2010 | 08:29 AM
  #10702
maximer's Avatar
come on clutch ideas please!!! lol, i need to know what clutch brands most of you guys use for around 350wtq. this is a pretty good estimate of what i will be at on nitrous. input! 3.5L 6spd 5.5 gen is the application
Old May 22, 2010 | 04:21 PM
  #10703
rockboy's Avatar
Im new here and plan on buying a maxima in a few weeks I always like the maxima's!!
I have two in mind
A 2000 white Gle with 103k miles for 5k the carfax also came back clean.
http://www.lemonfree.com/48147926.html-1
The 2nd one is a metallic green 2002 gle with 128k for 5,192 it's also has rims and tints and it recently was reduced a 1,000
http://www.dpaa2.com/inventory/detai...=9150#tippytop
Which one is the better deal once again Im new here thanks in advance
Old May 23, 2010 | 12:17 PM
  #10704
AUTOmobilePHILE's Avatar
Heyy guys, I need a little help with my fogs. I currently have completely stock fogs, and I am looking at get the yellow HID bulbs to put in my stock lenses. Can I do this as a swap from the stock bulbs to the yellow HID ones, or do I need to get a HID conversion kit? Thanks!
Old May 23, 2010 | 02:47 PM
  #10705
MarkKlooster's Avatar
Driver Side Boot Repair
I have had boot damage for awhile and have been driving with it while I decide what to do. Should I just get the boot damage repaired or have the whole axle replaced? Will replacing the axle fix any and all damage from the damaged boot? If I replace the axle on the driver side should I also replace the axle on the passenger side? Here's a photo of the current damage.
Thanks for your help!
Old May 23, 2010 | 03:08 PM
  #10706
NmexMAX's Avatar
dot dot dot ...
Its best to replace the entire axle since dirt and other crap in t here and cause damage.
Old May 24, 2010 | 08:21 AM
  #10707
homeyclaus's Avatar
Headache? Explain?
Sure: how many dollars for x amount of performance gain? Will the same 500 dollars spent, on a stock maxima, on intake and exhaust improvements get one more or less felt performance improvements? How much time does it take to tune the electronic solution until the maximum benefits are realized?
My point was that installing a piggyback or other "chip", and its calibration is the last thing you do in most cases, unless you enjoy driving around with laptop in the passenger seat. You generally need the other improvements to actually take advantage of electronic mods, or end up doing them anyways, so why do it backwards?
Old May 24, 2010 | 09:10 AM
  #10708
NmexMAX's Avatar
dot dot dot ...
You gotta pay to play.
And it depends on your perspective and depth of how far you want to go with it.
Old May 24, 2010 | 09:26 AM
  #10709
deadwrongtd's Avatar
does anyone know where to get catbacks or cold/short air intakes for 2002-2003 maximas?
Old May 24, 2010 | 09:33 AM
  #10710
NmexMAX's Avatar
dot dot dot ...
Cattman has catbacks as well as a # of other places. He also has intakes as well. Umm, search a little maybe
http://forums.maxima.org/5th-generat...fications.html
Old May 24, 2010 | 09:54 AM
  #10711
homeyclaus's Avatar
I never argued that. The argument is that given $500, $1000, or $2000, and a stock max, getting an electronic mod is not where I'd start.
Old May 24, 2010 | 09:56 AM
  #10712
NmexMAX's Avatar
dot dot dot ...
The only reason I took slight offense was because both you & Sooner mentioned they aren't worth it on our car, and I thought that was vague and slightly misinformed.
Old May 24, 2010 | 03:03 PM
  #10713
ihavetheki's Avatar
Headers catback install
I am new and I was trying to get a walkthrough or some pictures or something as far as trying to install aftermarket headers and a catback exhaust. When I found some how-to threads they linked to the wrong thread. Hopefully this thread can point me in the right direction. Thank you.
Old May 24, 2010 | 03:14 PM
  #10714
BlackHawk3G's Avatar
Lets say i want to swap my 3.0 into a 3.5... How much will i have to spend for the block? and how much can i sell my 3.0 with 78,***miles on it?
Old May 25, 2010 | 09:16 AM
  #10715
BCmaxima2's Avatar
2001 Trans stuck in 2nd when starting out cold.
Well, I've searched and I don't see anyone with this particular problem.
The issue is that when the max is cold, it's like (in fact I'm sure) the trans is stuck in 2nd and is very doggy starting out. If I hold the throttle on gently for about 2-5 seconds, the trans suddenly kicks down/in and the car pulls out normally. This problem will happen on the first 2-4 stop signs, then the trans will act normal for the rest of the day.
The problem started about 2 months after a trans service which is the first since I bought the car about 3 years ago so I'm wondering if it's related.
I took it back to the trans shop and left it overnight. They were able to re-create the symptoms but came back with "your engine is not running correctly and not able to generate the power to pull out" to which I call BS. The engine never misses a beat and generates great power. Mileage is about 140,000 kms.
Any suggestions or anyone else having this particular shifting issue.
Old May 25, 2010 | 09:31 AM
  #10716
NmexMAX's Avatar
dot dot dot ...
Is your OD light on even when OD is not on? Does it blink?
Old May 25, 2010 | 09:35 AM
  #10717
BCmaxima2's Avatar
Good point. I'm sure it's never blinked but I couldn't say whether the light was on. The only OD light I remember is the OD off light when you disable OD with the switch.
I'll check after work today.
Old May 25, 2010 | 10:46 AM
  #10718
01-maxima-24's Avatar
I dont think you can just swap bulbs, go to ddmtuning.com, they have HID kits for $30. If you want yellow then get the 3000k H3's, not hard to install either, just follow one DIY write-ups on this forum.
Old May 25, 2010 | 10:47 AM
  #10719
I need help. Long story short, after either working on my foglight rewire or installing my mirror turn signals (can't remember which one it was), I blew some fuses, replaced them, and now when I lock my car with the wireless keypad, only my horn chirps, but no lights flash. Could this be a fuse, or something else? I know my hazard fuse is good because that was one of the fuses that I blew, as well as my turn signals. They are now replaced. Please help.
Old May 25, 2010 | 11:03 AM
  #10720
Awesome man, thanks. That's real cheap. What size bulb is in the fog lights?
