5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Aug 21, 2007 | 10:49 AM
  #2801
CCS2k1Max's Avatar
Originally Posted by irish44j
the lights are an easy install. Only tweaking necessary is removal of chrome 20s..
Wasn't this thread a "newb flame free zone"?
Old Aug 21, 2007 | 10:54 AM
  #2802
Kyle00's Avatar
WSH for teh cup
That wasn't so much a flame, just more of his opinion. (and mine also)
Old Aug 21, 2007 | 10:59 AM
  #2803
shawnpwilson's Avatar
Originally Posted by Kyle00
No, the PCV Valve should be "sticking out" of the valve cover with a hose attached to it
Would it be sticking up towards the hood (if the hood were down), sticking back towards dashboard, sticking down towards ground, or sticking towards side fender? Is it a straight attachment or does it look like an elbow attachment? About how many inches is it from say the Throttle cables?
Old Aug 21, 2007 | 02:09 PM
  #2804
Reizy's Avatar
Originally Posted by shawnpwilson
I have search the entire net looking for an image of where the PCV valve would be located on the 2000 SE. I have looked at PCV valves at various parts stores but cannot find anything that closely resembles that. Is the part complete embedded in a hose or hidden under a component? I know where my MAF and throttle wires are. So any description starting from any those reference points should be good.... even better an image with an arrow would be fantastic. Thanks to any help on this.
Hey Shawn, from one newb to another......http://phatg20.net/modules.php?name=...ownload&cid=73 Download the FSM and learn alot. Have fun with it. Its 36 MB and thousands of pages.
Old Aug 21, 2007 | 02:49 PM
  #2805
irish44j's Avatar
retired moderator
lol, I made my commentary answering his question that the lights are an easy install. Since he threw in unrelated information re: his 20s, I threw in an unrelated response re: his 20s
Old Aug 21, 2007 | 04:11 PM
  #2806
Reizy! Wow! Thank you very much. I'm now overwelmed with all I could ever have. This is great... I've been looking for a service repair manual for quite a while. Nissan sells one if I can remember correctly for some 250+ odd dollars? (or was that the CD?) Maybe more. Whatever it was, it turned me away pretty quickly. I'm so happy to have this series of PDF's. Now hopefully I will stop asking dingdong questions which drive the pro's and semipro's nuts propbably. Can't thank you enough!
Old Aug 21, 2007 | 07:14 PM
  #2807
lannal554's Avatar
Hey whats up guys, anyways i have a 2000 maxima auto and was wondering if it was possible for a transmission swap to a manual 6speed or 5speed? If so i was wanting to know how much this might cost and if anyone else has done this?
Old Aug 21, 2007 | 07:19 PM
  #2808
irish44j's Avatar
retired moderator
http://forums.maxima.org/showthread....ht=5speed+swap
Old Aug 21, 2007 | 07:55 PM
  #2809
lannal554's Avatar
thanks, just what i needed
Old Aug 21, 2007 | 08:03 PM
  #2810
spencer.justin's Avatar
tryin to max out the max
is it possible to replace my cloth seats with power leather ones if i find the seats and the motors? are the wiring for the motors already run under the seats or does that have to be done also?
also if heated seats are available can the switch on the console be added?
anyone know?
Old Aug 21, 2007 | 09:16 PM
  #2811
DasYears
anyone know?
the wires should all be run already (i think heated seats too) and when you find leather ones they are a direct replacement, just plug those seats in
Old Aug 21, 2007 | 10:07 PM
  #2812
awesome, thank you
Old Aug 22, 2007 | 11:14 PM
  #2813
MAFS input signal circuit open
In following the FSM procedure for testing the MAF circuit I have found that the input signal circuit from MAF terminal 1 to ECM terminal 61 is open; no continuity. Now I was going to blindly replace my MAF tomorrow because of the SES p0100 code is set now. But a kind fellow, Reizy, posted a link to the FSM ( a few posts back), and I decided to take a stab at the check procedures. So now, my SES code of p0100 may not really be a physical problem with the MAF for the wiring instead.
Now my questions are... has anyone mess around with correcting wiring of this sort? Is this a big project that I should leave and let the dealership handle this? If I let the dealership handle this, should I just let them figure it out from the beginning? Or should I share what I found with them. Wouldn't that tick them off that I attempted to troubleshoot and correct this problem myself...thinking I'm trying to take away their work/jobs? Please tell me your thoughts. Thanks.
Also, after erasing the SES code earlier yesterday, it stayed off all day. Tonight when I went through the MAF check procedures, I disconnected the battery before disconnecting the ecm harnesses. After reconnecting everything and going for a short test drive (10 MIN) the SES tripped again but this time with p0147...system too lean bank 2. Could this be a result of the faulty MAF circuit? Or is the ECM trying to relearn everything and spitting whatever is most convenient first? Thanks.
Old Aug 23, 2007 | 08:33 AM
  #2814
93 SE's Avatar
the middle support bar is bent in and so is ac condensor, i was wondering 1. is it safe to bend back the condensor, knock it straight with a rubber mallet ....2 is the upper bar one piece with the whole radiator support or can the bar be unbolted off separatley
damage to support is similar to this http://forums.maxima.org/showthread.php?p=5693881 except no headlight damage etc just look at middle of support bar and condensor doesnt seen that badly bent
Old Aug 23, 2007 | 02:31 PM
  #2815
i cant find a non-billet grille on the entire internet
any help?
thanks
Old Aug 23, 2007 | 03:12 PM
  #2816
Kyle00's Avatar
WSH for teh cup
any help?
thanks
you could make your own like many people do...
Old Aug 23, 2007 | 03:33 PM
  #2817
really, what about the interface, clips of some sort or direct bolt on, hmmm
gonna have to think on this one
it hurts
Old Aug 23, 2007 | 07:09 PM
  #2818
pbn85's Avatar
I may be considering headers if my other plan to get into the 13s does not work...anyway is it safe to put headers on a relatively new engine? I have a new engine with 2300 miles from Nissan due to my previous oil burn problem. I was thinking back pressure during the exhaust stroke will change how the piston rings get seated. Just curious...
Old Aug 23, 2007 | 09:41 PM
  #2819
farmercist's Avatar
"im new here and have a question"
Im currently looking at picking up a 02-03 maxima (auto). I currently drive a cobalt SS (supercharged) and im over it, it was fun/fast, but now its no longer practical, i hate driving manual, and i hate the 2 doors, oh and the fact that its in the shop every 2 weeks ? yes literally every 2 weeks
What are the positives/negatives of these 5.5 gens?
any input is appreciated, thanks.
Old Aug 23, 2007 | 09:44 PM
  #2820
it aint a chevy
Old Aug 23, 2007 | 09:46 PM
  #2821
farmercist's Avatar
it aint a chevy
well obviously, i previously owned a 01 maxima, and now im back..but what was improved for 02-03, my 01 had problems with the tranny, was that improved at all for the 5.5s?
Old Aug 23, 2007 | 11:52 PM
  #2822
MaxBoost925's Avatar
Drug Money
Pros:
More power
Bigger seats
HID headlights
Looks better
Cons:
Some VQ35's burn oil
Weak MAF
Weak wheel bearings
Weak coilpacks
...This question has been Org Vice Squaded.
Old Aug 24, 2007 | 04:48 AM
  #2823
Kyle00's Avatar
WSH for teh cup
it hurts
here's a link to some grills people have made themselves for the 5.5 gen.
http://forums.maxima.org/showthread....me+depot+grill
Old Aug 24, 2007 | 04:50 AM
  #2824
Kyle00's Avatar
WSH for teh cup
Originally Posted by MaxBoost925
Pros:
More power
Bigger seats
HID headlights
Looks better
Cons:
Weak MAF
Weak wheel bearings
Weak coilpacks
thats pretty much it right there
Old Aug 24, 2007 | 05:47 AM
  #2825
SoonerFan's Avatar
Cletus
the 3.5 is better...no questions.
i have owned both and my 02 burns oil. but i still like it better than my old 00
IMO, the 02-3 is the best maxima made...which is why i own one
Old Aug 24, 2007 | 05:49 AM
  #2826
Kyle00's Avatar
WSH for teh cup
I agree, my next max will be a 5.5 gen
Old Aug 24, 2007 | 04:07 PM
  #2827
TurtleHead
Sooner, I see you are moving into my turf soon? You will have to help me out with my ride!
Old Aug 24, 2007 | 06:39 PM
  #2828
pbn85's Avatar
10char
Old Aug 25, 2007 | 10:36 AM
  #2829
tbombs32's Avatar
any one know what the best (brightest) white 194 LED is best for the 5.5 parking light. theres so many types i dont know what to go with. anyone have pics of the different kinds?
Old Aug 25, 2007 | 02:49 PM
  #2830
NmexMAX's Avatar
dot dot dot ...
10char
The sooner the better.
@ weak CP's re: 02/3's.
Old Aug 25, 2007 | 08:00 PM
  #2831
alicious's Avatar
the org...not what it was
autolumination.com's 9 Led SMT Tower II is hella bright, and should meet your needs
Old Aug 26, 2007 | 05:20 AM
  #2832
tbombs32's Avatar
so you would recomend those over the i think there the wedge shaped ones that have 7 LED's that all point forward 270 degrees
Old Aug 26, 2007 | 07:25 PM
  #2833
aackshun's Avatar
I tried searching but it's quite complicated if you ask me.... so I hope I dont get flamed for asking this but.... Are 02, 03, remotes compatible with a 01?
And how are those Ebay black headlights? Krap? Or Decent? Anyone have expeirience with them?
*edit*
one more thing.... in the sunset/sunrise the dash seems quite dim, i tried turning the dash lights all the way up/down and still everything seems quite hard to see, any common mods done to this? LEDs? etc?
Old Aug 26, 2007 | 07:29 PM
  #2834
Drug Money
Ebay lights suck. Period.
Old Aug 26, 2007 | 07:36 PM
  #2835
aackshun's Avatar
Ah as I thought, that's usually the general consensus with ebay parts, but there are a few exceptions.
Old Aug 26, 2007 | 08:04 PM
  #2836
alicious's Avatar
yes, because of that reflective shield that's in your housing you want light coming out of all sides, not just a big concentration going forward. And as far as "brightness" is concerned they aren't quite as bright as the ones i mentioned. I know this because i've had both, and the people over at autolumination have confirmed this as well.
Old Aug 26, 2007 | 08:10 PM
  #2837
alicious's Avatar
*edit*
For the first question the answer to that i believe is no, because of the features that are available with the 5.5's that aren't with ours (i.e. one touch windows down capable), but someone correct me if i'm wrong.
Second question is yes, they are garbage and unless you plan to make a project out of them by replacing the projector don't waist your time.
Third, there's several memebers on here that did a complete swap with the backlighting for the gauges, do a quick search and you'll find what you need. But if it makes you feel any better, i understand and share the same pain/issue with you
Old Aug 26, 2007 | 09:02 PM
  #2838
DeVBLacKMaX's Avatar
I just hit a wall.
I just bought a 00max black se about a month ago.
Unfortunately earlier tonight, I banged into a small concrete wall and effed up my muffler and scratched up my back bumper. Anyone know a website where I can get a stock replacement muffler? Like EXACT stock replacement for a 2000 SE.
Help is much appreciated.
Old Aug 27, 2007 | 04:08 PM
  #2839
TurtleHead
There are numerous places to get one: dealer, websites, etc. Just search for OEM Nissan parts.
In the mean time, you can read over this:
http://www.nissanexhaust.com/
Old Aug 27, 2007 | 05:20 PM
  #2840
Psyfa's Avatar
i had a bit of an accident, long story short...
how much does a rear wheel axle cost to replace?
