5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Oct 3, 2007 | 08:49 AM
  #3201
alicious's Avatar
the org...not what it was
Originally Posted by El_PrOfE
something better...as I plan on intake header and exhaust along with suspension. wanna be a little faster so that is why i wanna go with better brakes and a nice set up .
thanks for that IIRC thing I was oblivious to it.
Also I have seen a new with the Nissan red caliper is that custom or from another car that fits the 03 maxima?
....ok, so you mean a BBK? Your looking to get a BBK, yes?
Old Oct 3, 2007 | 02:26 PM
  #3202
MoeBelikeMax's Avatar
Just Did the Fog Light Rewire Mod Cost me 2 DollarS AND TOKE ME 5 MINS 2 DO
Old Oct 3, 2007 | 02:33 PM
  #3203
El_PrOfE's Avatar
I really do not know as of yet I was just wondering cus I had seen some people with the big red caliper that says nissan so that is part of a bbk?
Here is what I am thinking of going with so far. the Brembo drilled slotted with the Pbr pads...so would the stock caliper be okay to still use or should I also get new calipers?
Old Oct 3, 2007 | 04:24 PM
  #3204
TurtleHead
Why drilled and slotted rotors? You plan on racing at a track? If none of these, just get Brembo blanks.
Old Oct 3, 2007 | 04:55 PM
  #3205
El_PrOfE's Avatar
Idk lol to tell you the truth I really do not know the whole brake thing and what each disk represents. I am trying to learn as I go.
Old Oct 3, 2007 | 05:03 PM
  #3206
NmexMAX's Avatar
dot dot dot ...
Spend time in this forum and learn all you can learn BEFORE you post.
http://forums.maxima.org/forumdispla...aysprune=&f=68
Old Oct 3, 2007 | 05:08 PM
  #3207
User 12822's Avatar
What could be causing my tranny to shift slower as of late?
2000 Auto SE
Old Oct 3, 2007 | 05:10 PM
  #3208
NmexMAX's Avatar
dot dot dot ...
2000 Auto SE
Lots of things. There’s a TSB for the VB as well as solenoids. Check the stickys, and yes, that link (TSB) works because I checked last week.
Old Oct 3, 2007 | 06:07 PM
  #3209
El_PrOfE's Avatar
Thanks alot (not being sarcastic.)
Most of the links do not work but I guess they are working on that. Thanks again some real good info.
Old Oct 4, 2007 | 08:20 AM
  #3210
choopster's Avatar
while putting a new dvd player i busted my cars auto lightening feature. I tried locating the bad fuse but no luck. My cars light stays on no matter how sunny it is on the auto setting. can anybody tell me how to fix this problem. Is it possible i might have fried the photo sensor.
thx
Old Oct 4, 2007 | 09:45 AM
  #3211
Kyle00's Avatar
WSH for teh cup
2000 Auto SE
Because of neutral dropping?.....
Old Oct 5, 2007 | 10:16 AM
  #3212
chaoticchao's Avatar
wrx turbo inside maxima?
if i was to put a wrx turbo into my maxims, what would i possibly have to go through? my friend's getting a bigger turbo for his wrx and he's going to probably trash the old one so i just wanted to know if i can fit it in or not.
Old Oct 5, 2007 | 10:25 AM
  #3213
Kyle00's Avatar
WSH for teh cup
It's plug and play! Go for it.
No, it's umm... how do i say this... Possible of course but not likely at all.
Old Oct 5, 2007 | 11:45 AM
  #3214
SoonerFan's Avatar
Cletus
you act like its gonna be easy
good luck with that...please dont start threads to ask about how to do it...that could go on for years
Old Oct 5, 2007 | 03:15 PM
  #3215
hoboscratch's Avatar
Originally Posted by hoboscratch
I'm replacing my shocks/struts this weekend. The front of my car is sagging about a half inch on the front driver side and a quarter inch or so front passenger side (based on FSM). Rear is perfect. Do I need to worry about replacing the springs? Would hate to go thru all that work to replace the struts only to replace the springs later. I drive my car about 4k per month for work and don't want a lowered stiffer ride. Just going for comfort (too bad the "comfort your sole goal" thread is busted in the sticky). Also, anything else I should definitely replace since I'm doing this other work? Thanks
no thoughts on the springs?
Old Oct 5, 2007 | 05:05 PM
  #3216
El_PrOfE's Avatar
do the 5.5's even have a plug and play turbo or supercharger? or an easy set up?
Old Oct 5, 2007 | 05:06 PM
  #3217
willsmax00's Avatar
Ok probably been discussed multiple times before, tried searching for related words per Sticky's, but unsuccessful.
I jus purchased a 00 max in july, started to noticed ticking/clicking noise from engine during throttle less than a month ago. Took to Nissan today, they checked it out and said its the coils are bad, not enough spark causing knock.
Anyone else come across this?
Thanks for any help!
Old Oct 5, 2007 | 08:27 PM
  #3218
Armon's Avatar
New Question(s):
1) In many of the potentially helpful stickys, the links are either dead or lead to the wrong threads. I guess this is more a statement than a question.
2) About a year ago, I was considering buying a RSB. I searched and found a GREAT thread here that went through a very detailed how-to with pictures at each step along the way. I didnt end up doing the mod, and now that I am considering it seriously again.... i cant find it anywhere! And yes, I searched my heart out.
This time around, I want to get the Cattman combination FSTB and RSB. I'd like to find a good how-to thread for each, if they exist. At least one of them existed at one point, but I'm worried that it has been lost in an old thread graveyard.
Ideas?
Old Oct 6, 2007 | 11:49 AM
  #3219
6SPD02SE's Avatar
I have looked all over and cant find any threads about this... How do I get my fog lights to come on without my headlights?
Old Oct 6, 2007 | 01:38 PM
  #3220
CoolMax's Avatar
is invisible
http://www.innerbean.com/housecor/fog_rewire.html
Old Oct 6, 2007 | 01:39 PM
  #3221
Little John's Avatar
Just found out the pipe connecting my muffler to the rest of the exhaust is broken at the flange. Apparently it's a failing common to the model (got an '03 with an '02 exhaust system), and the mechanic quoted me more than I want to pay to replace it. Do I have to replace the whole muffler or will welding fix it? Also, if I have to replace it, what muffler options are there besides Nissan OEM? Keep in mind that I don't want a muffler that sounds like an exhaust leak (ie. no bling, please!).
Old Oct 6, 2007 | 01:43 PM
  #3222
CoolMax's Avatar
is invisible
http://forums.maxima.org/showpost.ph...10&postcount=1
http://www.moodym.com/maxima/tech/addcorsb.html
basically same process
Old Oct 6, 2007 | 02:57 PM
  #3223
zheka's Avatar
boy am i stupid.... i just put paint thinner like chemical on my 2000 headlight, and now its faded, can i sand it down then polish it, or am i screwed?
Old Oct 6, 2007 | 03:39 PM
  #3224
seby86's Avatar
there should only be surface damage....thats the great thing about plastic, u can sand it down, remove the top layer and repolish it. try using 2000 grit sand paper and thoroughly sand the down the headlights. then using a plastic polisher like Meguire's plasticX (available at wal-mart for like 7 bucks, or autozone), buff off the scratches the sandpaper created. its alot better to use an electric buffer, but if you dont have one, then make sure you buff really hard, use lots of elbow grease on it and that should do the trick.
Old Oct 6, 2007 | 03:54 PM
  #3225
6SPD02SE's Avatar
Awesome, thank you very much!!
Old Oct 6, 2007 | 05:02 PM
  #3226
CoolMax's Avatar
is invisible
http://forums.maxima.org/showthread....91#post3743491
Old Oct 6, 2007 | 09:41 PM
  #3227
Armon's Avatar
Perfect, thanks!
Old Oct 7, 2007 | 09:06 AM
  #3228
JMWarren's Avatar
Well, I didn't have any luck in the I35 Newbie thread so I thought I'd try here.
I've seen that it's possible to rewire the fogs to work with the parking lights. Is it possible to do the same with the day time running lights on a Canadian car?
Thanks!
Old Oct 7, 2007 | 09:07 AM
  #3229
TurtleHead
Has anyone found a way to rewire the fog lights to allow for operation at any time (ie. Headlights off)? As well can they be tied into the ignition so that there is no way to accidentally leave them on and drain the battery?
Thanks!
Just a few post above yours! Fogs can come on with parking lamps.
Old Oct 7, 2007 | 09:16 AM
  #3230
6SPD02SE's Avatar
My front passenger side axle nut came loose and now the threads are stripped. The nut wont budge and if i drive it the wheel might fall off. I even broke a ratchet trying to get the nut to move. Any suggestions?
Old Oct 7, 2007 | 09:21 AM
  #3231
TurtleHead
Aren't these reverse threaded? I can't remember.
If it is truelly stripped, you probably have to take a datco with a cutting wheel and cut the nut off.
Old Oct 7, 2007 | 09:25 AM
  #3232
6SPD02SE's Avatar
Not reverse thread, i backed the nut off a little to put some lock tight on and now the nut wont budge. Im assuming it got stripped somehow. Or its cross threaded.
Old Oct 7, 2007 | 02:57 PM
  #3233
seby86's Avatar
DAM..u're lucky. it cost me $2.87... i hate you!
Old Oct 7, 2007 | 03:00 PM
  #3234
GigEmAgs07's Avatar
is there a way to re-aim the vents at my feet in a 2k max? my toes get effin freezing. It shoots right at my right big toe, which becomes a popsicle on longer trips. any way to do it?
Old Oct 7, 2007 | 03:54 PM
  #3235
SoonerFan's Avatar
Cletus
put shoes on
Old Oct 7, 2007 | 04:02 PM
  #3236
machinehead131's Avatar
put the heat on
Old Oct 7, 2007 | 04:14 PM
  #3237
GigEmAgs07's Avatar
gee thanks.
Old Oct 7, 2007 | 04:33 PM
  #3238
seby86's Avatar
i would say just get down and look under there....locate the vents and just stare at them, touch them, feel them, wiggle them around... look at how they are mounted.. can they come off? can u some how remove them and replace them in a different manner? you have to get a little resourceful and creative sometimes....
Old Oct 7, 2007 | 06:39 PM
  #3239
6SPD02SE's Avatar
Have the air come out the dash vents instead of the floor.
Old Oct 7, 2007 | 06:58 PM
  #3240
hippee's Avatar
2001 maxima
car started running rough and tends to stall at lights and lacks power often. service engine light is lit intermittantly. checked the code and it displays "0171". this lists several items. if anyone has had a similar problem, could you please suggest a good starting point so i dont have to reinvent the wheel? thanks
