HELP - programming new remote...
Old Aug 27, 2006 | 07:37 AM
02SEinStL's Avatar
I want to program a remote from my last '02 for my new one, and I *know* the instructions are here somewhere, but it's telling me I don't have permission to do a search(!?)......can anyone point me to the directions?
THANKS!
Old Aug 27, 2006 | 07:59 AM
GBAUER's Avatar
I think the info is in your owner's manual. Look in the area where they say how to change the battery in the remote.
Old Aug 27, 2006 | 08:18 AM
02SEinStL's Avatar
Thanks - that would be too easy
I found some 6th gen. instructions and it worked
If it really is in the manual, then the guy I found who's SELLING instructions for $6.95 must really be hoping to find a sucker!
Old Aug 27, 2006 | 11:10 AM
H8tank's Avatar
Can you share those instructions please? I have been trying all day to reprogram a new remote, with no luck, I have followed a variety of intructions inluding these: http://www.nissanhelp.com/Ownership/...am_key_fob.htm
The very first time I did the key in-out 6-10 times, I did see the hazards flash, and it appeared the programming was successful, but the key fobs do not work.
After subsequent attempts, I don't get the initial flash, but following the remaining instructions, the flashers do blink twice when hitting the keyfob button, so I 'know' they are communicating.
Any help is appreciated.
Old Aug 27, 2006 | 12:18 PM
misiek's Avatar
Old Aug 27, 2006 | 01:37 PM
H8tank's Avatar
Thanks for the intructions, they are pretty much the same as I have found and tried, I follow them to a 'T', but I cannot get the flashers to show I have entered programming mode as stated in Step 2. I have tried all speeds, the only thing I have succesfully done is manage to make the old fob inoperable like the new one.
Any ideas? Car is basically stock, except for aftermarket Pioneer deck and Steering wheel audio button controller.
Old Aug 27, 2006 | 03:36 PM
02SEinStL's Avatar
Maybe it locked you out after too many tries? Or maybe you're not making the "6 times within 10 seconds" time limit? (although the directions I found said 15 seconds...)
Old Aug 27, 2006 | 04:22 PM
H8tank's Avatar
Is this possible? If so, is it on a timer?
Trust me, 6-12 times in 10 has been attempted in more ways than positions in a 900 page kama sutra book.
Old Aug 31, 2006 | 10:21 AM
H8tank's Avatar
Any advice here? I cannot get the car to enter programming mode as listed in step 2.
Old Aug 31, 2006 | 10:34 AM
four's Avatar
its crazy easy. i dont know why you cant do it.
not sure what the problem is.
are you completely taking the key out when you're attempting the 6 times thing?
Old Aug 31, 2006 | 10:53 AM
H8tank's Avatar
Yes, I've tried everything, I don't want to go to dealer over something so trivial... I am quite able around a vehicle, so I don't think this is an ID-10T error.
Old Aug 31, 2006 | 12:39 PM
Canepole
There is a time limit. You gotta stick it in and out 10 times (making sure to completely remove it) in something like 7 sec.
Old Aug 31, 2006 | 02:25 PM
H8tank's Avatar
I've done it fast, slow, every which way you can think of.
Weird thing is, if I do all the steps, and hit the button on the remote, the flashers do blink then, so I know it can tell its there, but of course they are not really programmed when I try them out.
Its that initial flash to let me know I am in programming mode I cannot seem to get, it did it ONCE the very first time I beleive, but never since.
Old Aug 31, 2006 | 02:29 PM
MIXXMAX's Avatar
Make sure you have the correct serial number and FCC number or the key fob will not work correctly. The key fob MUST match the original numbers of the original key fob that came with the car. If they don't, and you try to program the wrong frequency, the flashers will flash like crazy or not flash at all. Also, when doing the steps in programming, timing is the key or it won't work properly. Each time you mess up, you have to make sure you reset the procedure by starting over...open up the driver's door and start over.
Old Aug 31, 2006 | 10:31 PM
SilverGLE's Avatar
I'm watching you, boy...
^ Exactly... I followed some similar instructions, but I didn't have to have all my remotes with me, just the one extra I wanted to program (but I didn't have the max of 4 already programmed to my car, either).
Old Apr 16, 2007 | 11:18 PM
tijkane's Avatar
Awesome! Just programmed mine for my 06 maxima.
Thanks for the directions!
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
flu2000
Sep 14, 2015 12:34 PM
