Battery issues ...
Old Sep 5, 2006 | 07:47 AM
Mints33's Avatar
Battery issues ...
Ok, when I went to start my car up yesterday, it wouldn't, the days prior to that, it started, but the battery sounded weak. So, I took a charger to it, and according to the charger it was fully charged later yesterday evening, after about 7.5 hours. It started fine this morning, drove it around, started it a few times without problems. However, I come back home and hook the charger to it, and it's still charging, I mean shouldn't it read FULL? Does it sound like there's something wrong w/ the battery and/or charging system? I don't believe it's the alternator, since that tested good. Could it be the battery just can not hold a charge? What's the price for a Nissan battery, or a good price anyway? Any help would be great!!
Old Sep 5, 2006 | 07:51 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
How old is the battery? I had a very similar problem...turns out the battery had a bad cell. Time for an Optima...
Old Sep 5, 2006 | 08:04 AM
Mints33's Avatar
Oops ... forgot to mention, it's a 2000 maxima SE, original battery. Where did you go to have your battery tested?
I've seen that avatar, aren't you on OC?
Old Sep 5, 2006 | 08:09 AM
Not sure what OC is.
Yeah, your battery is long gone, my friend. Surprised it lasted so long. Time for a new one.
tsk808's Avatar
if it's the stock battery, it's time to change. Just replaced my stock last month, had to trek it to napa, paid $70 with the cash back on the old one.
put the new one in, you'll notice it scream to life.
Old Sep 5, 2006 | 08:12 AM
Mints33's Avatar
What brand of battery do you guys recommend? Stay w/ the original Nissan battery?
Old Sep 5, 2006 | 08:16 AM
Optima Red or Yellow top.
Old Sep 5, 2006 | 08:20 AM
Mints33's Avatar
Thanks, but that's a little too steep for my wallet. Wow.
Any tips on changing out the battery? Unhook negative, then positive, remove battery, place new battery in, and hook -, then +?
Old Sep 5, 2006 | 08:21 AM
Yep, that's it.
Old Sep 5, 2006 | 09:56 AM
Mints33's Avatar
Thanks all!
Well, here's what happened, took the car to Autozone to have the battery tested, just to be on the safe side, it was measuring at 8 volts, yikes!!! Then of course it wouldn't start again, so got a jump, so it turns out, there was probably a dead cell. Unfortunately, I went with a Autozone battery, I guess not so unfortunate, just wasn't my first choice. I've heard Duralast batteries aren't so bad, better than stock.
Old Sep 5, 2006 | 11:54 AM
Orgullo's Avatar
$$ Ballin on a Budget $$
If you have any kind of aftermarket system, LED's or anything extra, save your yourself some money in the long run and get yourself an Optima Red / Yellow. You'll be glad that you did.
Old Sep 5, 2006 | 12:04 PM
Mints33's Avatar
Yeah, fortunately for me, I don't have any aftermarket items which require additional drain on the battery, except a bug deflector on the hood, but that doesn't require any power. hehe Besides that, my girl is bone stock.
Old Sep 5, 2006 | 01:27 PM
misiek's Avatar
a new optima would be the first "mod" then
Old Sep 5, 2006 | 01:39 PM
Dude, you're doing the right thing. An Optima is ideal, but if you don't have any mods, stick to what's within your budget.
Old Sep 5, 2006 | 03:39 PM
PAREDLINE's Avatar
I STRONGLY recommend the walmart EVERSTART MAXX battery. I think it is hands down the best battery I have ever used. You can take off the walmart sticker if that bothers you but you will not be unhappy with this $60 battery.
Get the biggest one with the most Amps (I think its 1000CCA 900CA). It'll fit just fine
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
gustavison
Oct 4, 2015 06:50 PM
wingnut2006
Sep 19, 2015 06:13 AM
markevans999
Sep 10, 2015 04:29 PM
