Fast way for L.E.D.'s
Old Sep 10, 2006 | 09:12 AM
BLK2BLU's Avatar
Im sure that someone has already come up with this somewhere, but I did not check. This dawned on me at 2 this morning when I was laying in the bed. I have tried to sauder L.E.D.'s before, but I suck after about 10 min. of it. This way all you have to do is put some duct tape or something over it to protect the leads. Tell me what you think, and if this already exists, let me know.
Old Sep 10, 2006 | 11:32 AM
SinCityMaxPower's Avatar
It works, but the reason I personally would rather solder the leds is so I know 100% that when they are sealed up in lets say a tail light housing, for example, they will never rattle or shake loose.
On the other hand if you had that set up in an accesable area it might not be so bad.
But I can solder pretty quickly so I dont think I would use that method either way.
Old Sep 10, 2006 | 11:36 AM
BLK2BLU's Avatar
I am going to wrap it all in electrical tape and its going to be in the trunk. I think this way is better for the straight line, however something like Metal does (and a few others) with going all out with everything, it is better to do it another way. I just wanted something more for a straight line and to be a little different.
Old Sep 10, 2006 | 03:19 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I don't see any resistors on there
Old Sep 10, 2006 | 04:31 PM
BLK2BLU's Avatar
Metal I sent you a PM about that...dont worry tho, that was a 9V on there long enough to take a pic
Old Sep 10, 2006 | 07:04 PM
How do you have them wired? Are you using a resistor? How many are in the string? Are you running into any problems?
Old Sep 10, 2006 | 07:45 PM
BLK2BLU's Avatar
all of that was in the PM did you get it?
Old Sep 10, 2006 | 07:48 PM
zagzig's Avatar
Share the problems you're having! And, Metal, please share the answers.
Old Sep 10, 2006 | 08:06 PM
BLK2BLU's Avatar
Im using this site for the resistor calcs...URL=http://metku.net/index.html?sect=view&n=1&path=mods/ledcalc/index_eng#[/URL] I am using blue LED's (5000MCD) and I think that gives me a 4.5V drop. Im trying to have 20 led's in parallel running off the 12V from the car. I put in 20milliamps for the calc. as well. It tells me to get a 22Ohm resistor with a power rating of 5 watts. The only problem is that I cant find that resistor at Radio Shack.
My question is: #1, Have I put in everything the way I should and #2 is there a way to get around not being able to use this resistor
Old Sep 11, 2006 | 06:10 PM
BLK2BLU's Avatar
bump for some help
Old Sep 11, 2006 | 06:17 PM
Run 5 legs of 4-LEDs (in series) parallel; this way you will be able to avoid using a resistor.
Old Sep 11, 2006 | 06:19 PM
frankd121's Avatar
A 22 ohm resistance seems really low. I believe the proper calculation to get the proper resistance should be 4.5V/(20 milliamps). That results in a resistance of 225 ohms. You can get a 0.5kohm (500 ohm resistor) and you'll be perfectly fine.
Old Sep 11, 2006 | 06:57 PM
BLK2BLU's Avatar
What if I did it like this? (there is actually 22 LED's in all....I did not feel like drawing the rest)
If each LED makes it drop ~4V would this work? Actually I know it will work, but what about the milliamps on this
Old Sep 12, 2006 | 05:35 AM
BLK2BLU's Avatar
will this last? or will there be too many milliamps?
Old Sep 12, 2006 | 07:53 AM
Old Sep 12, 2006 | 12:47 PM
BLK2BLU's Avatar
the 4 led's are in series...make five sets of those.....then have them all in parallel? It that how you mean it?
Old Sep 12, 2006 | 01:46 PM
Precisley. You'll be right as rain.
Old Sep 12, 2006 | 06:38 PM
Dr. Roy's Avatar
If you dont plan on having the LEDs on that often, then the way metal sugested will work fine, particularly if you dont want to use resistors and dont want to/cant solder.
if you plan to have these on a lot then you may want to include some resistors in your design, it will provide minimal protection to the LEDs from transient overvoltage. the best way to do it would be to include a voltage regulator.
LEDs that get regular use, and do not use a regulator will last less than a year.
lrb6805
Sep 30, 2015 08:12 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
pears
Sep 18, 2015 05:25 AM
