oil light?
Old Sep 16, 2006 | 08:44 AM
albundy's Avatar
oil light?
i noticed today that my oil light was on, and i knew i was past time for a oil change. so i went and had it changed and the light is on but dimmer now?? any suggestions or anyone else had this symptom before? thanks in advance
Old Sep 16, 2006 | 01:25 PM
VaporHead
Try disconnecting battery for an hour and see "if" it resets. Thats the easiest thing I can recommend without tearing into the cluster.
Old Sep 16, 2006 | 01:34 PM
infiniteecho's Avatar
I had my oil light come on about 150 miles after my first oil change when I bought the car. It went out on it's own after an hour of driving. Did the same thing to me after the second oil change. (I bought the car used with 50,000 miles and change my oil every 3,000 miles religously)
The light would dim and then go out if I reved it past 3500 RPMs. No, my car doesn't have the oil consumption problem... yet. If that matters.
Old Sep 16, 2006 | 01:38 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
reset the ECU by following what Vaporhead said
Old Sep 16, 2006 | 04:55 PM
NmexMAX's Avatar
dot dot dot ...
Oil light = low oil pressure.
Old Sep 16, 2006 | 05:45 PM
rmd0311's Avatar
Is it a 5.5?
Old Sep 16, 2006 | 05:56 PM
albundy's Avatar
light went out tonight..im wondering if it had something to do with driving through some deep water yesterday when i was down the shore..place was flooded!!..oh well ill keep and eye on it to make sure it doesnt come back on..thanks
Old Sep 16, 2006 | 06:51 PM
P. Samson's Avatar
Salt water and the connector on the LOP switch don't mix and my guess is the circuit was grounding and putting the light on..... BUT for next time as NmexMAX explained this is a LOW OIL PRESSURE light....NOT a "low oil level" light or an "oil service required" light or some such thing. If the light doesn't go out after starting, shut the engine off or if it comes on when driving then pull over, stop and shutdown the engine. And by the way driving through any water deeper than about 6 inches is just asking for problems.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
sdotcarter
Sep 2, 2015 09:53 PM
