Battery issues
Old Sep 18, 2006 | 08:38 AM
maxima_rob's Avatar
Battery issues
Hey guys, I had to replace my battery prematurely becuase it started leaking and getting that crusted dried battery acid everywhere. Now with my new battery I'm having the battery light come on again (no more than 50 miles). I opened to hood to see what was going on and I noticed that some liquid was being spewed by the vents on top of the battery. Is this normal? I'm thinking it's not the battery now. Any suggestions? Bad terminal maybe?
I thought I checked and everything looked ok.
Old Sep 18, 2006 | 09:05 AM
P. Samson's Avatar
The battery is being overcharged and it sounds like the whole area is contaminated with acid which is a safety hazard to you and the engine compartment. You need to remove the battery, flush and wipe down the whole area around and under the battery holder etc. with fresh water (anything that has the white residue). The alternator has an integral (I believe....I don't have access to an FSM right now) regulator which has failed. I think this is an alternator change here.
Old Sep 18, 2006 | 09:32 AM
misiek's Avatar
also double check your grounds
Old Sep 18, 2006 | 10:26 AM
maxima_rob's Avatar
Thanks for the response guys. Noob question here, but where are the grounds located?
Old Sep 18, 2006 | 10:27 AM
maxima_rob's Avatar
Would it be difficult to replace out the alternator myself?
How much to they run?
Old Sep 18, 2006 | 11:04 AM
misiek's Avatar
look for the wire connected to the neg on the battery and follow them until they end -- check the screw a teach location to make sure there is a good clean connection to the chassie
as for prices on the alt im not too sure but wanna say around $75?
Old Sep 19, 2006 | 06:56 PM
super6's Avatar
i noticed mine started leaking a bit, but its wierd, its leaking only at the corners, jist a little, recomended to get new one or its ok to leave it??
Old Sep 19, 2006 | 07:01 PM
Mints33's Avatar
If it's the original, it probably needs replacing. I replaced mine a couple of weeks ago, huge difference!
Old Sep 19, 2006 | 08:30 PM
SilverGLE's Avatar
I'm watching you, boy...
A rebuilt alt from anywhere but the dealer will run you $140-$180. I got mine from AutoZone for $140. Installation was $145... About 2 hours of labor. Good luck!
Old Sep 20, 2006 | 05:09 AM
maxima_rob's Avatar
Thanks for the suggestions so far guys. I started getting the abs and brake lights coming on too. I know there is no problems with them so I thought this might help diagnose the issue if someone had seen this before. I did get an underdrive pulley put in a while back which I'm told affects the battery, but I have not had problems until recently.
Old Sep 21, 2006 | 06:27 AM
maxima_rob's Avatar
Wow, I'm really surprised at the knowledge here. I took it to the shop and it was in fact that alternator. It's gonna cost me $515 to replace out. That includes the diagnostic fee. Oh well. How long is the alternator supposed to last?
Old Sep 21, 2006 | 06:40 AM
naxray's Avatar
FWIW - that sounds really high for an independent shop. I just had mine replaced at the stealer for less than that.
Old Sep 21, 2006 | 06:43 AM
maxima_rob's Avatar
Hmmm... how much was it at the dealer?
Did they have to do a diagnostic. I think they charged me a $100 just ofr that.
Old Sep 21, 2006 | 06:46 AM
naxray's Avatar
$450 ish. They ran a diagnostic but did not charge an additional fee for doing so. I had the BATT and BRAKE lights come on.
Old Sep 21, 2006 | 06:59 AM
maxima_rob's Avatar
ughh.... normally these guys are reasonable. oh well, live and learn.
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
wingnut2006
Sep 19, 2015 06:13 AM
markevans999
Sep 10, 2015 04:29 PM
